Possible Hot Vlan
Re: Possible Hot Vlan
@Faizan786
Looking at your connection details there is an issue of some sort, the Line attenuation reading is extremely high for the reported Maximum data rate.
Also the slow upload speeds might cause issues during a cloud saves or similar due to router buffer bloat.
I would suggest reporting a fault using the instructions found here:- https://www.plus.net/help/report-a-problem/
Faizan786
Fixes: 387
As @Dan_the_Van Says above, you clearly have a line/connection issue - just report it.
Faizan786
Only have issues after 6pm during the day it's perfect.
Faizan786
During day
Faizan786
Current!
Fixes: 387
As said above - report a fault.
@Faizan786
You have included further information about your connection this time
Some thing is wrong, looking at the Hubs reported modulation says you have a ADSL connection
What product are you on?
Checking again G_993_2_ANNEX_B is VDSL. but I would not expect to see VPI/VCI settings as those are usually for ADSL
Fixes: 582
True, but this IS a BT Hub!  and probably old firmware ?
@Faizan786
It would be helpful it you upload the event log from your Hub
Should be found in > Advanced settings >Technical Log >Event Log. There should be an option to save or export the event log, it is saved to your devices download folder
Use the paper clip icon below to attach it to a post.
Faizan786
I have followed your advice and sent event log. Many thanks, hopefully it could get sorted remotely as it only happens in the evening. Last time it was hot vlan and bt moved me over. Let's see what you get from event logs.
Faizan786
Opera Snapshot_2024-11-01_202238_192.168.1.254.pngOpera Snapshot_2024-11-01_202429_www.thinkbroadband.com.png
Right now compared to earlier.
Faizan786
Yes a bt hub. It was suggested by this forum years back when people were having major issues with plusnet. To be honest ive never looked at any issues at all since getting bthub until now.
Fixes: 387
Do you have any other?
