Port Forward Foscam IP Cam with the Plusnet Hub One Router
- Port Forward Foscam IP Cam with the Plusnet Hub On...
02-03-2017 12:37 PM
Hi.
I'm trying to connect my Foscam IP cam with the Plusnet Hub One router. However, I could not access the camera outside of the home.
I did register for the static IP. However, when ever I enter the static using a browser, nothing happened. Is there anything i've missed out?
Re: Port Forward Foscam IP Cam with the Plusnet Hub One Router
02-03-2017 12:57 PM - edited 02-03-2017 1:00 PM
Presumably you are trying to access the IPcam externally using your static IP and correct port number.
Maybe the facility you are accessing from is blocking the port.
02-03-2017 1:02 PM
Yes i did. Strangely up till now nothing happen.
I even tried using a no-IP application and only have access if i'm using the home wifi using the fix IP 192.168.1.000:6969.
If i'm correct the static IP and DNS would be like this: 212.00.000.000:6969 (000 is assumed a number).
Now i'm out from home. Though I try to access the static IP, it did not direct me anywhere.
02-03-2017 1:15 PM - edited 02-03-2017 1:19 PM
Is your static IP definitely up and running?
Foscam IPcams usually use something like port 81 or 88 by default.
I presume you have altered it for security reasons.
02-03-2017 1:17 PM
Should be. Please see the attached image below when i checked the connection setting.
02-03-2017 1:29 PM - edited 02-03-2017 1:29 PM
When I was setting up a Foscam camera I configured the Foscam app on my phone with the wifi turned off.
This made it easier to test the router configuration.
I don't use the Hub One unfortunately.
02-03-2017 1:30 PM
Yes, it should be running and i've doubled check with the customer service on phone.
In addition, I also assigned my static home IP within the foscam setting. This is to prevent it from constantly changing. For example: 192.168.1.154:6969
However, the static IP i bought from plusnet does not actually work (i.e. direct me to an error page). For example, if i typed 202.99.9.999:6969 (presume my static ip: 202.99.9.999)
02-03-2017 1:35 PM
Advanced Settings -> Firewall -> Port Forwarding
02-03-2017 1:36 PM
I tried connecting using both LAN and WIFI to coonect with my foscam app (via android). However, it wasn't a success. Therefore, i had to the setting using my PC.
02-03-2017 1:37 PM
I did. I'll show you the print screen when i'm back home, later on.
03-03-2017 2:00 PM
Please see the images below. I've tried.
In addition, since i switched to a static IP by paying plusnet and detect it (image: what is my ip). Using this IP i tried putting in the broswer with and without the port (e.g. 202.50.000.000:8609), and nothing happen.
Did i miss anything?
08-03-2017 2:15 PM
