Poor Fibre with Intermittent
goldenlady46
Fixes: 5
Before we on Unlimited Fibre with line rental everything was stable and get 40/10 max speed. Then Changed to Unlimited Fibre to Fibre (SoGEA 80/20) the service went unstable and intermittent all the time since May 14th. The fault is now open with Openreach engineer attend tomorrow at 8am to 1pm due to network fault. Plusnet also sending out new Plusnet Hub Two Router to replaced Plusnet Hub One.
The ticket was on hold https://www.plus.net/wizard/?p=view_question&id=241950473
The Plusnet Hub One Router sync was awful 46/15 expecting that to be 80/20 say on BTw Checker Range A 80/20.
29 REPLIES 29
goldenlady46
Fixes: 5
Re: Poor Fibre with Intermittent
Broadband sync now reduced to 40/12 that's not good service for 80/20
goldenlady46
Fixes: 5
Engineer (Mike) just been this morning spend two hours try to fix outside in my local area (network issues) and came back with bad news as he spoken to the network manager as the broadband at the cabinet is too full (crosstalk) and reduced down to 37/8 as he isn't happy about it and saying it should be over 55/19 but he will come back in three weeks time try to get it fixed. Also put new Plusnet Hub Two router on it.
Not happy at all. We paying for the service 80/20 not 40/10? Are we on the correct profile 80/20?
A line attenuation of 15.6 would suggest your property is about 0.5 Km from the green cabinet. For 80/20 the green cabinet would need to be outside your property.
See https://www.increasebroadbandspeed.co.uk/chart-of-bt-fttc-vdsl2-speed-against-distance-from-the-cabi...
The state of the internal phone extension in you house can also impact the line attenuation, that is why the recommendation is to use the master socket.
Your speeds maybe impacted but I suspect the Openreach technician is correct in his findings
The BT Availability should be used with caution as it does not take into account your physical connection condition. With every contract plusnet detail the speeds of your connection and MGS (Minimum Guaranteed Speed) mostly it is this plusnet will refer to.
Edit: You may be on the wrong profile.
willcutforth
Fixes: 113
Profile is all swimming from our side @Dan_the_Van
 Will Cutforth
goldenlady46
Fixes: 5
@willcutforth Profile is all swimming from our side - what on earth does this mean? Plusnet has closed fault with no explained where the engineer full report?
Fixes: 391
@goldenlady46 In other words, your profile is set correctly. The engineers report has probably not even reached Plusnet yet, and in any case, these are not usually passed to users - they are full of jargon which most would not understand.
goldenlady46
Fixes: 5
The engineer told us he will be back in three weeks time to fix this issues out but why plusnet closed the fault without no engineer report on it. Nothing is explained. Fault closed ticket saying it been resolved but how on earth it resolved when the line was down to 37/8 as BTw checker handback say 54/18!
goldenlady46
Fixes: 5
@Dan_the_Van We got no dial tone on the line as there is no phone servive as we now on SOGEA 80/20 service with sync at 37/8. Engineer did say it should be more than that as he did say the issues got nothing to do with inside the property, it the network issues at the cabinet. Engineer isn't happy about it. So do we all. Forget to add: engineer say the Full Fibre will come soon in next year around June July 2025. He say Full Fibre will solved the 80/20.
Fixes: 391
I obviously don't know the full story but the 'I'll be back in three weeks' line seems strange - engineers go to jobs when they are told to - not on a whim.
goldenlady46
Fixes: 5
The engineer (Mike) told me, mum and dad explained he will back in three weeks time to sort this issues out. That's all we know by his wording.
@willcutforth Please can I have GEA Test result please!
goldenlady46
Fixes: 5
@Gandalf
I think my parents BTw Performance Test no longer work as I just want to check her profile rate on their line. Without it can be very annoying now because I think Plusnet has now removed current line speed via this link: https://portal.plus.net/member-centre/broadband as we don't know what her current ip profile on her line? I know PN can do GEA Test to check it.
Below it off-topic as I just tested my BTw Performance Test for my own line G.fast sync 255.96Mbps with my difference ISP with BTw IP Profile showed the correct for my line speed 247.49Mbps.
Screenshot below (this is my G.fast line not my parents FTTC line)
@goldenlady46
Looking at the members centre I see
This is the redacted text I received in an email titled "Confirmation of your new contract" on the date I renewed.
There is the section "Your Broadband Speed"
Here's all the speed details you need to know.
Unlimited Fibre Extra has an average speed of 66Mb download and 18Mb upload.
At peak times, we estimate that you'll get the following speeds on your line:
Download: nn - nnMb
Upload: nn - nnMb
Minimum Guaranteed Speed: nn.nMb.
This line would reflect the end users contract with plusnet.
The BTW Performance Test for me has not worked for over 12 months.
Hopefully someone will post a GEA test for your parents connection.
goldenlady46
Fixes: 5
@Dan_the_Van  @Gandalf @willcutforth
We think the Engineer (did not resolved the job proper) The speed was way off from 80/20 product we are paying. This is very poor indeed with 37.67Mb / 8.83Mb using new Plusnet Hub Two Router.
Found in PN email:
Your broadband speed
Fibre has an average speed of 50Mb download and 9Mb upload.
Download: 46 - 52Mb
Upload: 8 - 9Mb
Minimum Guaranteed Speed: 42Mb.
I will wait for PN to run GEA Test
goldenlady46
Fixes: 5
Updated: Just spoken to PN asked for the GEA Test but they say don't do GEA Test anymore to customer but arranged to booked the engineer again for Monday 1pm to 6pm slot. They say the fault is reported High resistance fault because of low sync rate
