Plusnet outage
tijara33
Fixes: 6
Re: Plusnet outage
I've just noticed that I also lost connection in the early hours. Come on PN, please tell us what the h*ll is happening.
RichardB
Seasoned Champion
Fixes: 39
Re: Plusnet outage
I believe that last nights issues will be due to BT wholesale maintenance.
See http://www.plus.net/supportpages.html?a=2
PN use the BT Colindale, BT Faraday, Stepney & BT Colombo nodes to connect into the BT Wholesale network.
Thus, whenever BT perform maintenance on those nodes PN customers can be disconnected.
Richard
EDIT to include Stepney.
Anotherone
Champion
Fixes: 21
Re: Plusnet outage
http://usertools.plus.net/status/archive/1409579961.htm
If you lose PPP at that sort of time of the morning it's usually due to maintenance.
Justin7
Re: Plusnet outage
Any news on why the major Plusnet outage last week?
It'd be reassuring they know what caused it / what has been done to prevent it from reoccurring!
Bookworms
Re: Plusnet outage
My connection has been very slow over much of today and yesterday.
In fact it's been a bit flaky ever since the outage.
I don't want to report a fault if this is a system-wide problem. Undecided
AndyH
Re: Plusnet outage
@ Bookworms - Is it FTTC or ADSL? If ADSL, can you post your line stats from your router?
@ Justin7 - Hopefully, Kelly will give an update.
Justin7
Re: Plusnet outage
Thanks Andy, I am curious to read what caused the outage.
Thankfully the connection has remained stable since.
Bookworms
Re: Plusnet outage
Quote from: AndyH
ADSL.
Here you are (I'm guessing these are not great):
Product Name: TG585 v8
Software Release: 8.2.7.8
DSL Connection
Link Information
Uptime: 0 days, 10:41:46
DSL Type: G.992.5 annex A
Maximum Bandwidth (Up/Down) [kbps/kbps]: 856 / 9,048
Bandwidth (Up/Down) [kbps/kbps]: 920 / 6,488
Data Transferred (Sent/Received) [MB/MB]: 24.96 / 166.36
Output Power (Up/Down) [dBm]: 12.0 / 20.0
Line Attenuation (Up/Down) [dB]: 24.0 / 41.5
SN Margin (Up/Down) [dB]: 4.0 / 9.5
Loss of Signal (Local/Remote): 327,678 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 466,870 / 0
FEC Errors (Up/Down): 39,072 / 0
CRC Errors (Up/Down): 1,923 / 448,220
HEC Errors (Up/Down): 507 / 1,721,198
Most of the time the connection feels stable enough but every so often things crawl to a halt.
The interface of the router is quite sluggish at the best of times.
Bookworms
Re: Plusnet outage
I don't mean to hijack the thread, but I'd be grateful if someone could comment on the above stats.
To my untrained eye they look quite bad.
Anotherone
Champion
Fixes: 21
Re: Plusnet outage
The speed isn't bad for your connection but it's with a Target SNRM of 9dB by the looks of it, so could be better. The ES & CRC errors are not good, in fact bad and will be slowing your throughput a lot, and are probably the cause of drops and raised Target SNRM.
Can I suggest you start your own thread on this board and post the latest stats, also run  the BTw Performance test (ignore the red preamble except make sure no other programs are using the Internet) and at the end of the first run, click the Further Diagnostics button, enter just your Phone number and Run the Further Diagnostics Test.
Do a Copy and Paste of the results and post them (no need to grab an image). Also your Current Line speed (Login required) but don't post your phone number!
Bookworms
Re: Plusnet outage
Cheers, I'll start a new thread later.
I only posted here because I thought the slowdowns in my connection might be related to the more general recent outage.
Anotherone
Champion
Fixes: 21
Re: Plusnet outage
No problem Wink
Justin7
Re: Plusnet outage
PlusNet Guys - Any news on what has been done to prevent another outage?Huh
Anotherone
Champion
Fixes: 21
Re: Plusnet outage
It would be really nice if we could have an explanation of what really happened.
ejs
Aspiring Hero
Fixes: 25
Re: Plusnet outage
Last time I think details turned up on theregister.co.uk before anything was said here.
