Plusnet Two Hub issue?
George1956
I have just renewed my Unlimited fibre Extra contract, I also ordered a new Plusnet Two hub to replace my ageing Plusnet One hub.
The Plusnet Two hub arrived today, setting up was straightforward, but when i did a speed check my speed had dropped from around 45 Mbps with my old Plusnet One hub to around 31 Mbps with the new Two hub.
Yes i know it's only day one with my new hub, but this is a substantial drop in performance compared to the old One hub.
Any advice would be gratefully received.
Thanks in advance.
2 REPLIES 2
Fixes: 460
Re: Plusnet Two Hub issue?
@George1956
Arec you testing your speed über an Ethernet link or wireless? If wireless can you try using an Ethernet cable, this will determine whether this is a network or wireless issue.
George1956
Thanks for your quick response, i'm using a wired connection to my desktop PC.
PC is running windows 10.
Many thanks
