Please reset my line
- Re: Please reset my line
26-06-2015 4:30 PM
26-06-2015 11:01 PM
29-06-2015 4:13 PM
SNRM now down to one, 1,0000's of CRC errors but yet the upload is capped!
Download is over 18Mbps
Upload .443 (capped - almost 1/2 of the erroneous .888 figure - so something still not right)
> adsl status
--------------------------- ATU-R Info (hw: annex A, f/w: annex A) -----------
Running Mode : ADSL2+(G.992.5) State : SHOWTI
ME
DS Actual Rate : 18808621 bps US Actual Rate : 443928 bps
DS Attainable Rate : 17788000 bps US Attainable Rate : 1212000 bps
DS Path Mode : Fast US Path Mode : Fast
DS Interleave Depth : 1 US Interleave Depth : 1
NE Current Attenuation : 27 dB Cur SNR Margin : 1 dB
DS actual PSD : 20. 1 dB US actual PSD : 12. 1 dB
ADSL Firmware Version : 2471201_A
-------------------------------- ATU-C Info ---------------------------------
Far Current Attenuation : 14 dB Far SNR Margin : 30 dB
CO ITU Version[0] : 00004946 CO ITU Version[1] : 0000544e
DSLAM CHIPSET VENDOR : < IFTN >
29-06-2015 4:41 PM
29-06-2015 4:44 PM
29-06-2015 5:05 PM
See what happens tomorrow.
29-06-2015 6:17 PM
If I were you, I would do a graceful resync now (daytime) to allow it to goto the 3dB SNRM which will help reduce those errors, otherwise the DLM may decide to up the Target SNRM! (Remember, graceful = Disconnect PPP session, then power off for 10 minutes).
29-06-2015 6:36 PM
Will do a graceful re-sync in a moment whilst the sun is up!
Here's hoping
UPDATE: Back online SNR now 3.
> adsl status
ME
DS Actual Rate : 17816233 bps US Actual Rate : 443928 bps
DS Attainable Rate : 17816000 bps US Attainable Rate : 1200000 bps
NE Current Attenuation : 27 dB Cur SNR Margin : 3 dB
DS actual PSD : 20. 0 dB US actual PSD : 12. 9 dB
29-06-2015 7:02 PM
29-06-2015 7:13 PM
So far uptime is 21mins, CRC is 35, RX cells 120,478. / 8500 packets.
Yes, expecting to repeat tonight's reset tomorrow if SNR back to 1 after the uncap.
30-06-2015 1:57 PM
30-06-2015 3:42 PM
SNR down to 2 so will do a gentle restart in an hr or two whilst daylight.
30-06-2015 5:48 PM
Uptime: 3h 36
RX CRC errors: 624
RX Cells: 9487253
SNRM fluctuating between 2 and 3.
> show adsl
ME
DS Actual Rate : 17880985 bps US Actual Rate : 1208000 bps
DS Attainable Rate : 18216000 bps US Attainable Rate : 1208000 bps
DS actual PSD : 20. 0 dB US actual PSD : 11. 9 dB
Far Current Attenuation : 14 dB Far SNR Margin : 6 dB
01-07-2015 1:11 AM
01-07-2015 3:47 PM
15.7Mbps it is.
Currently seeing SNRM drifting between 2 and 3 is that a problem?
Rx CRC is 1945 for 11660817 Cells Rx'd - again is that an acceptable rate?
Thanks!
Graham.
