SNR
- SNR
SNR
30-06-2015 10:31 AM
Do you think plusnet (or any isp) will/could give the costumer the power to set their own Target SNR ?
It would be easy to add the option to the router software?
Re: SNR
30-06-2015 10:36 AM
Re: SNR
30-06-2015 5:03 PM
If a line is capable of being stretched a little then PlusNet ought to be capable of setting an appropriate SNRM. My line has an attenuation over 50dB and has run 350 days without break at a 3dB SNRM, despite an initial reluctance to lower the target from 6dB.
Re: SNR
30-06-2015 5:33 PM
But we got some interference from something and the SNRM got bumped up to 9.
We found out that the interference came from the WiFi extender part of my turned that off and the interference stop
Shame I cant get the SNRM back to 3dB
Re: SNR
30-06-2015 5:51 PM
Re: SNR
30-06-2015 6:34 PM
If plusnet could be so kind
Re: SNR
30-06-2015 6:40 PM
Re: SNR
30-06-2015 6:46 PM
Re: SNR
30-06-2015 6:51 PM
Line Status:Connected
DSL Modulation Type:ADSL_2plus
Annex Type:Annex A
Upstream
Downstream
Current Rate (Kbps)
1007 5548
Max Rate (Kbps)
1012 5772
SNR Margin (dB)
5.8 3.8
Line Attenuation (dB)
27.1 52.4
Errors (Pkts)
0 0
Re: SNR
30-06-2015 6:55 PM
Re: SNR
02-07-2015 6:50 AM
On the plusnet site it says my current speed is 4.8 hence my speed test is 4500 ish .
How long will it take the site to change it so its more inline with my sync speed..
Re: SNR
02-07-2015 12:11 PM
