Phone fine,BB dropping out.
anytbut
Well,started this morning so left routerstats running while i was at work (graph below).
Usual things checked (test socket,filter e.c.t ) gave CS a ring and told it`s a 3 day wait while it`s looked at. It`s a overhead line and before today it`s been fine,but seems to have coincided with the wind,but if it was something loose/broke then i guess the landline wouldn`t work also?
There was a BT engineer working at the top of the pole but when i shouted up he was working on lines for properties opposite me and wasn`t something general he was sorting.
Apart from equipment failure,what else might cause a intermittent BB but a working phone?
....BT speedtest added. (Between the dropouts!).
25 REPLIES 25
chrispurvey
Re: Phone fine,BB dropping out.
Your connection certainly doesn't look good for last night:
<img src="http://community.plus.net/visualradius/generated/image13814790329876.png"/>
Does your phone line have any interference or crackling?
anytbut
Was 1st thing i checked,expected the phone to sound like a box of rice crispies,but sounded fine even when the BB was down.
Was just about to post this reply when yours popped up Chris...
Line seems to behaving itself so far this morning after the last drop @ around 3am, sync and NM way down from normal tho...
Uptime: 0 days, 4:58:29
DSL Type: G.992.5 annex A
Maximum Bandwidth (Up/Down) [kbps/kbps]: 464 / 15,140
Bandwidth (Up/Down) [kbps/kbps]: 416 / 11,168
Data Transferred (Sent/Received) [MB/MB]: 11.64 / 129.90
Output Power (Up/Down) [dBm]: 12.0 / 19.5
Line Attenuation (Up/Down) [dB]: 31.5 / 20.5
SN Margin (Up/Down) [dB]: 13.5 / 17.5
Loss of Signal (Local/Remote): 65,538 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 65,538 / 0
FEC Errors (Up/Down): 1,568 / 938
CRC Errors (Up/Down): 3 / 1
HEC Errors (Up/Down): 13 / NA
, but had this in my help center questions..
"Provisioning of your ADSL Account Information
New Action 21CN Modify Submitted added
(via ADSL2+ Order System Interface)"
Only reference i can find is about interleaving?
......Just getting ready to leave for work and had a couple of drops on the BB,i`ll leave routerstats running again today incase. Smiley
orbrey
Interleaving is applied as a modify order, so that's what that'll be - hope it does stabilise things for you, if not we'll test further and get the fault escalated. Interleaving does help in a lot of these sorts of situations though.
anytbut
Didn't know interleaving was off,  but as the problem suddenly started, wouldn't that measure be "papering over the cracks" therfore hiding a underlying cause?
orbrey
It's possible, but if the line conditions have changed and interleaving is now necessary to hold a stable connection then it's a legitimate fix. We'll just have to see what happens.
anytbut
Left routerstats running while I'm @ work anyway so I'll see what I'll  come home to later.
Be a pita if interleaving is needed seeing I'm less then 300m from the exchange. 😄
anytbut
Back home and i can see there`s a drop around 12:30,NM looking better either side of it than this time yesterday.
Current stats....
Uptime: 0 days, 4:09:21
Maximum Bandwidth (Up/Down) [kbps/kbps]: 864 / 17,244
Bandwidth (Up/Down) [kbps/kbps]: 864 / 15,971
Data Transferred (Sent/Received) [MB/MB]: 12.37 / 371.31
Output Power (Up/Down) [dBm]: 12.0 / 19.0
Line Attenuation (Up/Down) [dB]: 7.5 / 9.0
SN Margin (Up/Down) [dB]: 19.5 / 12.5
Loss of Signal (Local/Remote): 196,607 / 0
Error Seconds (Local/Remote): 196,609 / 0
FEC Errors (Up/Down): 6 / 1,964
CRC Errors (Up/Down): 0 / 3
HEC Errors (Up/Down): 0 / NA
anytbut
Tried a soft reset this morning as the connection had been up for 20+hours...
Uptime: 0 days, 0:06:04
Maximum Bandwidth (Up/Down) [kbps/kbps]: 864 / 16,924
Bandwidth (Up/Down) [kbps/kbps]: 864 / 15,521
Data Transferred (Sent/Received) [kB/MB]: 489.00 / 1.91
Line Attenuation (Up/Down) [dB]: 7.5 / 9.5
SN Margin (Up/Down) [dB]: 21.0 / 12.5
FEC Errors (Up/Down): 0 / 6
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): 0 / 0
NM stuck on 12.5 db /DL sync about 3k+ lower as a result, it seems and my uncapped UL is lower too.
Would it be a 3 day wait, or being ADSL2 i thought it should pick up straight away?
anytbut
Well,interleaving was turned on this morning,here`s current line stats.....
Uptime: 0 days, 5:32:00
Maximum Bandwidth (Up/Down) [kbps/kbps]: 864 / 17,168
Bandwidth (Up/Down) [kbps/kbps]: 446 / 15,772
Data Transferred (Sent/Received) [MB/GB]: 85.75 / 1.04
Output Power (Up/Down) [dBm]: 11.0 / 19.5
SN Margin (Up/Down) [dB]: 32.0 / 12.0
Loss of Signal (Local/Remote): 3 / 0
Error Seconds (Local/Remote): 4 / 0
FEC Errors (Up/Down): 12,017 / 3,345
HEC Errors (Up/Down): 1,818,558,464 / NA
Has my uncapped upload been re-capped,also my NM seems stuck on 12db so DL sync is way lower that it should be for being so close to my exchange.
Just about to do a hard reset and monitor the connection with routerstats today.
anytbut
Question #75621505  can someone @ pn towers decipher that into English for me? Lol
Engineer visit requested, curious to the fact found in testing. 🙂
orbrey
LTB: Lower Threshold Breach, basically your downstream speed is less than the fault threshold profile set on your line.
Multiple drops - should be apparent, basically the tests have shown that the line is dropping.
ILQ: Not sure about the I but I know LQ is Line Quality - if it's Amber it means errors and/or drops have been seen on the line. This isn't necessarily indicative of a fault itself but when taken into account with the line's length and usual operating conditions/SNR etc it can do.
Jaggies
Quote from: Matt
<snip>
You said it...
Roll_eyes
anytbut
Engineer should be booked for Wednesday morning,hopefully get things running as they were.......and the text comes through....Wednesday afternoon,luckily that`s fine as the other half`s here.
Stats from the hard reset this morning....
Uptime: 0 days, 7:21:50
Maximum Bandwidth (Up/Down) [kbps/kbps]: 864 / 17,052
Bandwidth (Up/Down) [kbps/kbps]: 446 / 15,941
Data Transferred (Sent/Received) [MB/MB]: 1.13 / 3.84
Output Power (Up/Down) [dBm]: 10.0 / 19.5
SN Margin (Up/Down) [dB]: 33.0 / 11.5
Loss of Signal (Local/Remote): 4 / 0
FEC Errors (Up/Down): 12,032 / 2,423
CRC Errors (Up/Down): 1,281 / 3
5 min drop where PN were running tests @ midday. With a 9db downstream attenuation should i expect in a perfect world to have the connection maxing out?
Just done a BT speed test,upcapped uploads deffo gone,would that need re-ordering once the problems fixed?
anytbut
Now getting redirected to change the login to speedtest@speedtest_domain when running a speed test,but i get
"You appear to have not logged on as speedtest@speedtest_domain. In order to run the next test you should login as speedtest@speedtest_domain.
Please wait while you are redirected.."  Tho i have...anything i`m not doing correctly? (password field is blank).
