Pear shaped traffic shaping??
craiglay
Parents Plusnet internet connection (The old BBPlus account) has gone a bit pear shaped..
Off peak (Midnight to 4pm) seems to be rate limited to 128kbps Only web traffic with P2P blocked completely
Peak time seems to work at line speed (6200kbps), don't use P2P at this time.
Pings are very good at all times, just throughput
Run www.speedtest.net many times, BT speedtester shows similar, second test never works.
Any Ideas?
Craig
46 REPLIES 46
Fixes: 1,484
Re: Pear shaped traffic shaping??
Looks like your parents have blown the limits for the accoung, 4GB and 50GB off peak if my memory serves correctly.
pierre_pierre
more like Craig has blown it  Smiley
James
Hi Craig,
Feel free to PM me your parents username and I'll have a look at the account.
It does sound rather like the usage allowance has been exceeded though.
jelv
Fixes: 10
There's another user saying exactly the same thing on usenet p.s.c-f: news://usenet.plus.net:119/2008120308565316807-darren@pocketgpsworldcom
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Fixes: 1,484
Quote from: pierre_pierre
His parents might be in to P2P... Roll_eyes
Chris
Legend
Fixes: 169
Hi Craig,
Looking at the account I think you are talking about, the usage has reached over 50GB off-peak this month and therefore it should actually be rate limited 24/7.
As Jelv states, there is a similar issue (Premier not Plus) being discussed in usenet too so Dave T is currently checking your account and will make sure that it's on the correct profile now and after 4.
craiglay
Yup.. a little more digging reveals that the off-peak limit has been exceeded.. Too use to my old Premier account I had... Gonna have to grovel to upgrade it now
On a seperate note, had no email, or does it show up on the VMBU tool that i've exceeded my usage.
Cheers for your help
craiglay
Quote from: adiewoo
Old man does a lot of IPlayer, actually so do i...
jelv
Fixes: 10
Don't forget that if you are downloading programs you are probably uploading as well and PN counts the uploads.
Have a look at http://odmonitor.blogspot.com/
pierre_pierre
Quote from: jelv
I am currently looking at pocketgps forum, Daren is the Boss, getting mine at max speed.  have you a better link to the above?
craiglay
@Jelv - Yeah, gonna try get the parents to upgrade.. Ta for the link
@Chris or James - Any possibility of having interleave removed?  Tongue Syncing at 7616 SNR stable over 13Db
Cheers
jelv
Fixes: 10
If that link doesn't work for you its the latest topic in the plusnet.service.customer-feedback newsgroup so it's very easy to find.
James
Sure.  It won't improve the throughput speeds until billing passes though Wink
craig_p
Hi
I have had the same probs in the last 5 days as well. Im on prem  but have not gone over my monthly limit at all. All seems a bit strange to me  will interleaving have any effect on this?:o
