PPPoE changes?
- Re: PPPoE changes?
Re: PPPoE changes?
11-12-2009 12:59 PM
When did you call support? I've had a look at the account and from what I can see there you've definitely been moved to the 21CN service but at ADSL1 speeds. We placed the order on the 13th Nov and it'll have completed within a week of that, so might be a bit early to have caused this issue.
As per the radius logs Mark has sent you, there've been a lot of disconnections from the 1st through to the 5th though after the 5th it goes back to normal. I'm wondering if this could have been the cause.
Re: PPPoE changes?
11-12-2009 1:12 PM
What do you mean when you say I'm on 21CN at ADSL1 speeds? Is that because of the distance?
I'll try again tonight and see how I get on!
Re: PPPoE changes?
11-12-2009 3:12 PM
Are there any logs that someone could check to see if there is a problem? (I literally changed it about 2 or 3 min ago, and then changed it back again)
Ta!
Re: PPPoE changes?
11-12-2009 3:16 PM
Homesurf PlusDSL.net 195.166.128.87 active 15:10 11/Dec/2009 unknown 212.159.xxx.xxx Not set 15:10 11/Dec/2009 N/A 0:3:43 (on going)
Homesurf PlusDSL.net 195.166.128.87 ended 15:10 11/Dec/2009 unknown (User request) 212.159xxx.xxx Not set 15:10 11/Dec/2009 15:10 11/Dec/2009 0:0:2
Homesurf PlusDSL.net 195.166.128.87 ended 15:09 11/Dec/2009 static IP (User request) 212.159.xxx .xx Not set 15:09 11/Dec/2009 15:09 11/Dec/2009 0:0:2
Homesurf PlusDSL.net 195.166.128.130 ended 15:09 11/Dec/2009 unknown (User request) 212.159.xxx.xxx Not set 15:09 11/Dec/2009 15:09 11/Dec/2009 0:0:2
Radius reckons you're active and correct IP assigned.
Re: PPPoE changes?
11-12-2009 3:27 PM
Just tried PPPoE again, and it refuses to connect..
Does anyone have PPPoE auth working ok on 21CN?
Frustrating this!!!
Re: PPPoE changes?
11-12-2009 3:46 PM
Re: PPPoE changes?
11-12-2009 3:49 PM
http://192.168.0.1/setup.cgi?todo=ppp_debug to turn it on
http://192.168.0.1/ppp_log to view it
Reboot the router to turn it off
Re: PPPoE changes?
11-12-2009 5:12 PM
setting line discipline hook
Sending PADI
Terminating on signal 15.
Failed to negotiate PPPoE connection: 127
Sending PADI
Sending PADI
Options file - /etc/ppp/options.0.38.
connect_pppoatm_ses...Enter
connect_pppoatm_ses: socket created fd - 0x7.
connect_pppoatm_ses: setsockopt called.
connect_pppoatm_ses: connect successful.
Calling line discipline hook
Setting pppoatm line discipline.
vc encaps.
using channel 1
Using interface ppp0
Connect: ppp0 <-->
Couldn't increase MRU to 1500
sent [LCP ConfReq id=0x1 <mru 1492> <magic 0xd25e4911>]
rcvd [LCP ConfReq id=0xf9 <mru 1492> <auth chap MD5> <magic 0x25f9827b>] 00 00 00 00 00 00 00 00 00 00 00
sent [LCP ConfAck id=0xf9 <mru 1492> <auth chap MD5> <magic 0x25f9827b>]
rcvd [LCP ConfAck id=0x1 <mru 1492> <magic 0xd25e4911>] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Untimeout 0x407a64:0x1004a8b0.
sent [LCP EchoReq id=0x0 magic=0xd25e4911]
rcvd [CHAP Challenge id=0x1 <ad06f7d9ac90a3105a6ea3bf8e4199ba>, name = "bras-red1.pr"]
sent [CHAP Response id=0x1 <bf368089f6d65926d5f82ca157c329c8>, name = "xxxxx@plusdsl.net"]
rcvd [LCP ConfReq id=0xdd <mru 32725> <auth chap MD5> <magic 0x27975e88>] 00 00 00 00 00 00 00 00 00 00 00
Untimeout 0x40bb84:0x1004a8b0.
Untimeout 0x41028c:0x1004ab20.
sent [LCP ConfReq id=0x2 <mru 1492> <magic 0x3d053612>]
sent [LCP ConfAck id=0xdd <mru 32725> <auth chap MD5> <magic 0x27975e88>]
rcvd [LCP ConfAck id=0x2 <mru 1492> <magic 0x3d053612>] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Couldn't increase MTU to 32725
sent [LCP EchoReq id=0x0 magic=0x3d053612]
rcvd [CHAP Challenge id=0x4d <18c794618f90e12f32cfd9458dcd17dc>, name = "pcl-ag04"] 00
sent [CHAP Response id=0x4d <8e45430c4759dcee5462f55285f172da>, name = "xxxxxxxx@plusdsl.net"]
rcvd [LCP EchoRep id=0x0 magic=0x27975e88] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
rcvd [CHAP Success id=0x4d ""] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
sent [IPCP ConfReq id=0x1 <addr 0.0.0.0> <ms-dns1 0.0.0.0> <ms-dns3 0.0.0.0>]
rcvd [IPCP ConfReq id=0x71 <addr 195.166.128.135>] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ipcp: returning Configure-ACK
sent [IPCP ConfAck id=0x71 <addr 195.166.128.135>]
rcvd [IPCP ConfNak id=0x1 <addr 212.159.xx.xx> <ms-dns1 212.159.6.9> <ms-dns3 212.159.6.10>] 00 00 00 00 00 00 00 00
Untimeout 0x407a64:0x1004aab8.
sent [IPCP ConfReq id=0x2 <addr 212.159.xx.xx> <ms-dns1 212.159.6.9> <ms-dns3 212.159.6.10>]
rcvd [IPCP ConfAck id=0x2 <addr 212.159.xx.xx> <ms-dns1 212.159.6.9> <ms-dns3 212.159.6.10>] 00 00 00 00 00 00 00 00
ipcp: up
local IP address 212.159.xx.xx
remote IP address 195.166.128.135
primary DNS address 212.159.6.9
secondary DNS address 212.159.6.10
Script /etc/ppp/ip-up started (pid 1886)
sent [LCP EchoReq id=0x1 magic=0x3d053612]
rcvd [LCP EchoRep id=0x1 magic=0x27975e88] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
sent [LCP EchoReq id=0x2 magic=0x3d053612]
Script /etc/ppp/ip-up finished (pid 1886), status = 0x0
rcvd [LCP EchoRep id=0x2 magic=0x27975e88] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Re: PPPoE changes?
11-12-2009 6:00 PM
Re: PPPoE changes?
11-12-2009 6:12 PM
B.
Re: PPPoE changes?
11-12-2009 6:58 PM
So what have the buggers done?!
And more to the point, who can I shout at to get it working again???
Re: PPPoE changes?
11-12-2009 7:19 PM
So.. failing getting PPPoE working, I'll have to use that - but oh how I would rather be able to use my Cisco ASA or my Netgear Prosafe!!
Oh.. and if I get any more kit the missus is likely to take something sharp to me....
Re: PPPoE changes?
11-12-2009 7:39 PM
Re: PPPoE changes?
11-12-2009 7:50 PM
I presume when I switched over that it would disconnect and reconnect.
Also, when I was testing earlier this evening, it very very briefly connected using PPPoE and then within 30 secs had dropped the connection again!
Sigh!!
Re: PPPoE changes?
14-12-2009 10:30 PM
What would I be asking them to check?
Cheers..
