PN Speedtester up the creek?
- Re: PN Speedtester up the creek?
18-04-2009 12:27 PM
Couldn't get it to run, in the early hours or now. The page comes up but not a dicky bird when you press the button. Anyone else got a problem with it?
18-04-2009 12:36 PM
18-04-2009 1:01 PM
18-04-2009 1:27 PM
Anyway nothing wrong with the speedtester (apart from the results, but thats another matter).
18-04-2009 1:31 PM
Quote from: Anotherone I'll have to get the liverpool screwdriver out!
Hey watch it!
18-04-2009 2:53 PM
Plusnet tester seems ok today but was a bit iffy yesterday .Today however can not get the BT tester past the second stage of checking user ID - Keeps coming up with the message "unexpected error" etc
"if problem persists contact your isp ".
I wonder if this is connected with the dns problems currently refered to in the PN service status annoncement?
Is the BT tester working OK for others?
Edgeways.
18-04-2009 3:51 PM
18-04-2009 4:22 PM
Test1 comprises of Best Effort Test: -provides background information.
Your DSL connection rate: 8128 kbps(DOWN-STREAM), 448 kbps(UP-STREAM)
IP profile for your line is - 7150 kbps
Actual IP throughput achieved during the test was - 6125 kbps
Estimated line speed:
8 Mbps - Checked on 2009-01-26 08:39:58
Current line speed:
7150
18-04-2009 4:25 PM
18-04-2009 4:59 PM
I raised this as a problem some time ago. It seemed that when calling it up using the link at the bottom of the page, the web address provided left off the "Speedtest" bit off. I use Firefox 3 which may have something to do with that otherwise it may be the link.. I have got over the problem by Bookmarking the proper address and using that to get on and it has not yet failed to deliver.
Colintivy 🙂
18-04-2009 5:21 PM
Quote from: pierre_pierre
Quote from: Anotherone Stop showing off
That's not showing off - this is showing off:
That's on RIN. On ptn-ag1 the best I got was
18-04-2009 5:24 PM
18-04-2009 7:03 PM
19-04-2009 11:52 AM
I have had time to look at my earlier post on this topic, (73377.0.html of 20/02/09). Here Kelly was going to look into matters...he must still be busy!! I did suggest that there was no rush for an answer. It still seems that the link incorrectly leaves out the end of the address. Pressing the Begin button merely removes it leaving the display of the site blank with no action (just checked again). My alternative access still works reliably.
colintivy
19-04-2009 4:34 PM
However, this did cause me to observe that here is no mention on the main screen that Flash is required for it to 'run'. Perhaps if Kelly sees this, the info about Flash on the Graphs page could be reproduced on the main page.
