Option to look at / set Broadband/Fibre network settings disappeared?
mdplus
Apologies if I missed something, long time since visited plus.net.
You used to be able to click on a web link and go to the page with all your DNS settings, Static IP etc.
Been scouring the site after logging in today - can't see anything like this.
Though also their site seems a bit iffy when it comes to authentication.
Any ideas?
2 REPLIES 2
Fixes: 124
Re: Option to look at / set Broadband/Fibre network settings disappeared?
@mdplus
I assume you mean the members centre, the link seems to have gone
Looking through the help pages https://www.plus.net/help/broadband/understanding-your-ip-address/
In  >Is My IP Address Static or Dynamic I found Connection settings
Try https://www.plus.net/my.html?action=myconnection
Hope it works for you
mdplus
Thanks Dan - yes, the manual link worked for me.
Can then go to see full Connection Settings, though View My Usage goes 404.
Bit worrying - am about to renew my contract after probably almost 20 years of being with Plus - 97% due to the great support and good Forum - but IMHO website  gotchas like this (intentional Dumbing Down?) and tales of various services stopping (Mobi.plus Business?) often indicate choppy waters ahead.
When BT took over I thought we were all doomed - maybe the two letters I should have been worried about were 'EE' ...
Think I'll renew for 12 months only just in case.
Thanks again.
