No BTWholesale?
dougjbarnes1
No BTWholesale?
Just a general question, if anyone has any ideas.
Since my upgrade from Hub1 to Hub 2 there's a Broadband Speed test ¦[Test my speed] button
Sometimes this wouks and I get the old BTWholesale test screen, and can then run the speed tests from there
however
On about 50% of the times I only seem to get the background Dektop and nothing else. (see img). Pressing F5 to reflesh makes no difference.
Tried on Vivaldi & Chrome, same on both browsers.
Can anyone say why the test isn't available so often?
4 REPLIES 4
Legend
Fixes: 293
Re: No BTWholesale?
Try Crtl+F5 - or SHIFT+F5, can't remember which, offhand.
dougjbarnes1
Re: No BTWholesale?
Just tried and it worked straight off without any need to refresh, so will bear your idea in mind for the next 'no-show' (it's Ctrl+F5 you need, full refresh AND browser cache flush, had to remind myself as well.
AS an aside, I though, mid 2023, that BT were stating the Speed test was being phased out, has that been cancelled then?
Legend
Fixes: 293
Re: No BTWholesale?
I don't know about the phasing out, but I never use the BT test - being with Zen, my connection doesn't seem to be recognised half the time, and since I've moved to FTTP, I prefer other test sites anyway.
Re: No BTWholesale?
I have browsers Firefox, Chrome, and Chromium on my various PCs.
The ONLY way I can get  https://speedtest.btwholesale.com/  to reliably run
is to use Chromium and then going into 'incognito mode' before running the test !
