O2's Tu Go service No call volume on incoming or outgoing calls
- Re: O2's Tu Go service No call volume on incoming ...
Re: O2's Tu Go service No call volume on incoming or outgoing calls
22-04-2014 9:26 AM
I'm currently connected to gateway pcl-ag04.
Even though support noted those gateways as working please remember they only work for a short period after power cycling, 20-40 minutes or so later the seem to revert to not working as they should.
22-04-2014 9:32 AM
The university portal you can't access - can you try a traceroute and see where it fails?
22-04-2014 9:34 AM
PPP drops and re-establishments can readily happen without a resynch and in such cases happen very quickly. I have not identified the cause of this when I have seen it.
22-04-2014 9:37 AM
I can do a trace route but I don't have my partners login (that'll be tonight before I can test that) , I could trace route one of the other failing URL's? Would it also help if I performed the trace route on the same URL using both PN and O2? As O2 never fails to load the page would this give insight?
22-04-2014 9:41 AM
A traceroute to the URL address is fine (you won't need the login) - it would need to be in the format like community.plus.net (with no http or address after that). Just from your PN connection should be fine. In theory, if site does not load at all for you, the traceroute should fail somewhere.
22-04-2014 9:58 AM
Remember that he BQM needs a static IP address.
Cheers,
Kevin
22-04-2014 10:06 AM
22-04-2014 10:08 AM
Traceroute has been done on the three URL's that I have consistently seen failed page loads when connected to PN. My partners portal login will have to wait as I did not explain clearly before, I don't have the password or the URL as the login URL is not an issue, it's the post login URL which is affected.
Traceroute has started…
traceroute to voomka.com (192.163.208.88), 64 hops max, 72 byte packets
1 10.0.1.1 (10.0.1.1) 16.319 ms 4.502 ms 4.008 ms
2 lo0-central10.pcl-ag04.plus.net (195.166.128.185) 33.684 ms 29.402 ms 166.649 ms
3 link-a-central10.pcl-gw01.plus.net (212.159.2.172) 22.933 ms 161.174 ms 23.319 ms
4 xe-0-2-0.pcl-cr01.plus.net (212.159.0.204) 172.628 ms 23.520 ms 166.752 ms
5 ae1.ptw-cr01.plus.net (195.166.129.0) 24.841 ms 24.811 ms 164.632 ms
6 ae2.ptw-cr02.plus.net (195.166.129.5) 22.485 ms 22.542 ms 168.040 ms
7 10gigabitethernet5-1.core1.lon1.he.net (5.57.80.128) 32.408 ms 24.930 ms 164.482 ms
8 10ge3-1.core1.lon2.he.net (72.52.92.222) 22.663 ms 26.400 ms 163.524 ms
9 100ge1-1.core1.nyc4.he.net (72.52.92.166) 192.083 ms 151.339 ms 190.186 ms
10 100ge7-2.core1.chi1.he.net (184.105.223.161) 195.404 ms 165.051 ms 195.338 ms
11 10ge3-2.core1.den1.he.net (184.105.213.86) 195.845 ms 150.710 ms 193.831 ms
12 10ge4-2.core1.slc1.he.net (184.105.222.154) 195.048 ms 158.667 ms 192.342 ms
13 * * *
14 * * *
traceroute to offgridquest.com (162.144.62.181), 64 hops max, 72 byte packets
1 10.0.1.1 (10.0.1.1) 5.277 ms 4.039 ms 6.626 ms
2 lo0-central10.pcl-ag04.plus.net (195.166.128.185) 26.782 ms 24.422 ms 50.497 ms
3 link-b-central10.pcl-gw02.plus.net (212.159.2.174) 23.073 ms 24.132 ms 22.595 ms
4 xe-0-2-0.pcl-cr02.plus.net (212.159.0.206) 22.709 ms 27.181 ms 22.551 ms
5 ae2.pcl-cr01.plus.net (195.166.129.6) 25.250 ms 25.492 ms 44.163 ms
6 ae1.ptw-cr01.plus.net (195.166.129.0) 23.565 ms 22.756 ms 22.742 ms
7 * * *
8 100ge1-1.core1.nyc4.he.net (72.52.92.166) 287.554 ms 88.999 ms 94.092 ms
9 100ge7-2.core1.chi1.he.net (184.105.223.161) 107.591 ms 105.859 ms 105.773 ms
10 10ge3-2.core1.den1.he.net (184.105.213.86) 137.092 ms 135.370 ms 450.099 ms
11 10ge4-2.core1.slc1.he.net (184.105.222.154) 147.153 ms 147.047 ms 148.811 ms
12 * * *
13 * * *
traceroute to www.nyc-architecture.com (66.96.132.67), 64 hops max, 72 byte packets
1 10.0.1.1 (10.0.1.1) 4.333 ms 3.905 ms 3.932 ms
2 lo0-central10.pcl-ag04.plus.net (195.166.128.185) 24.165 ms 27.945 ms 23.277 ms
3 link-b-central10.pcl-gw02.plus.net (212.159.2.174) 22.754 ms 24.860 ms 22.369 ms
4 xe-0-2-0.pcl-cr02.plus.net (212.159.0.206) 22.645 ms 24.403 ms 22.536 ms
5 ae1.ptw-cr02.plus.net (195.166.129.2) 23.001 ms 31.943 ms 32.700 ms
6 ae2.ptw-cr01.plus.net (195.166.129.4) 22.496 ms 23.116 ms 22.448 ms
7 te-4-2.car5.london1.level3.net (217.163.45.249) 22.917 ms 22.909 ms 22.849 ms
8 ae-52-52.csw2.london1.level3.net (4.69.139.120) 24.647 ms 23.162 ms 22.952 ms
9 ae-228-3604.edge3.london1.level3.net (4.69.166.158) 23.060 ms 22.495 ms 22.708 ms
10 be3043.ccr22.lon01.atlas.cogentco.com (130.117.15.245) 24.103 ms 24.058 ms 25.308 ms
11 be2317.mpd22.lon13.atlas.cogentco.com (154.54.73.177) 25.591 ms
be2315.ccr22.lon13.atlas.cogentco.com (154.54.73.109) 24.450 ms 23.910 ms
12 be2391.ccr22.bos01.atlas.cogentco.com (154.54.44.237) 109.748 ms
be2389.ccr22.bos01.atlas.cogentco.com (154.54.44.181) 109.714 ms 111.895 ms
13 * * *
14 * *
22-04-2014 10:12 AM
22-04-2014 10:21 AM
22-04-2014 10:22 AM
Am guessing that it will not work?
22-04-2014 10:32 AM
There might be a setting for the Apple Airport to respond to ping requests.
22-04-2014 10:38 AM
Also, a quick check online of the Apple Airports and it would seem that you are NOT able to disable a ping sent to the WAN connection https://discussions.apple.com/thread/2376279
It looks like port 1 is used for this service, I have got port forwarding set to a server sitting on my network (which has a firewall set to stealth mode) however port 1 is not forwarded to it (it's manly a web and media server)
22-04-2014 10:48 AM
In the mean time I have disabled the local host on my router to see if this makes a difference.
22-04-2014 10:59 AM
So if you set your PS as the DMZ, all ping requests would be forwarded to it. If the PS is off, it won't respond etc.
Out of interest, can you try seeing if you can use the TuGo service with DMZ turned off?
