Noise Margin expectations?
- Re: Noise Margin expectations?
10-05-2009 6:51 PM
10-05-2009 7:04 PM
Jim
10-05-2009 7:11 PM
I am a bit out of my depth here but the more expert members on the forums may be able to offer more guidance.
10-05-2009 7:15 PM
10-05-2009 7:27 PM
my 50.5 db line on adsl2 bitloading below
11-05-2009 12:55 PM
Do you (know if you) live near any major radio transmitters? (I'll send you a PM).
11-05-2009 6:45 PM
No major radio transmitters nearer than 10-15 miles - television transmitters are all huge distances - no mobile phone antenna nearby either that I know of. No industrial plants
Its very hard to say when it started. I have been on a 1Meg line for circa 5 years without trouble but changed to max and to Pipex maybe 12 months ago and was pleased to get something faster than 1Meg. It was never going to be lightening as I am maybe 2 miles from the exchange.
Took some interest in speed about 3 months ago and installed a NT5 filtered front and reorganised my wiring a bit. The modem is within inches of the master socket but then has an ethernet cable going off to a wireless modem in the loft.. In normal operation there is a dect set and a standard phone plugged into the phone side of the filter and an extension wire going away around the house to various phone points - mostly originally put there for a modem to go next to the computer but now unused. Was pleased to get 3600kbits or thereabouts at that time. As said above, the evidence is that disconnecting all internal wiring makes no difference. I think the noise level was about a steady 10db at that time because I could not understand why it was so high. However, not solid evidence.
Maybe 3 weeks ago, everything stopped - broadband, phone, the lot. Eventually BT turned up and decided that they had accidentally disconnected us at the exchange. Got that sorted, no idea about the noise at that time but I am fairly sure the speed was still about 3600. So I then waited for my profile (caution - uneducated use of technical term) to go up.
Lately the net seems to have been very slow. Some pages just seemed to take forever to get started - but if I re-trigger them, they come in quick. However, I mostly use a Linux based laptop over the wireless connection and am always mucking round with it, so I am never too sure whether that is me or the net.
Anyway, the other day, I read the forum and some of the posts about speed. Loaded up Routerstat and found that my speed had dropped to something like 2900 and the noise margin was at a high of 3 bouncing down to 2 or 1 and to 0 occasionally. Mild panic, then had various other panics so left it. Eventually got back to it and found that it was now peaking at 10db with lots of drops to 7, 6 maybe 5. No reason I know of for the improvement.
Then as it was a Sunday and as I had some time, I disconnected the phones and did some tests and that brings us back in at the top of this thead.
Jim
11-05-2009 10:10 PM
Since I restarted the modem this morning, the bitswaps graph shows every tone has changed several times and some are going off the graph at the top.
So far the downstream synch speed is holding firm at 3700.
Jim
11-05-2009 10:21 PM
12-05-2009 5:32 PM
Jim
12-05-2009 10:05 PM
I am having a struggle to keep the telnet graphs recording - they work for a while then seem to stop unless I restart Routerstats or set the modem into debug mode manually. Any thoughts on what I am doing wrong there. (Ignore this if it just confuses the thread)
Jim
13-05-2009 7:46 AM
Keep listening to that phone line - all you should hear is a very quiet, barely discernable shhhh type sound. Any crackling or other intermittent noises indicates a possible connection problem somewhere.
13-05-2009 3:46 PM
13-05-2009 7:02 PM
But having got it set into debug mode and readings being taken, does yours not stop taking telnet recordings after a while.
I get the impression that my router decides that for security reasons (or computer stupidity) it terminates debug mode after some time (lets say 15 minutes, I have not timed it). It will not supply fresh data unless either I, or routerstats resends the debug mode command - and routerstats does not send it so I have to.
As soon as I send the command (from my browser), routerstats starts getting more data for a while at least.
I'll try to take a bit more notice of the times, that might be a clue. What I was wondering was whether I had missed some setting like "keep sending debug" but I guess not or you would have suggested it.
Jim
13-05-2009 8:43 PM
I will keep digging to find out how to alter it as it is greyed out at present
