No spare PCI slot on PC so what is optimum USB wi-fi adaptor?
Oldjim
Resting Legend
Fixes: 63
Re: No spare PCI slot on PC so what is optimum USB wi-fi adaptor?
That is why the one I recommended - and he is getting - has the aerial on a lead
HPsauce
Fixes: 4
Indeed, as USB wireless adapters go that's much better thought out than most.
(but why not do it right first time and fit an internal card?  Wink )
jelv
Fixes: 10
Because it may not be needed long term as he'd prefer to be wired. In which case he's got a spare, very quickly fitted USB wireless adapter. If some time in the future he got a laptop or something else with a USB port he's ready to go, but a card would be no help whatsoever.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
ejs
Aspiring Hero
Fixes: 25
Are you sure the 7717UN one has the antenna on a lead? It just looks like the USB stick is sitting in a stand to me. The data sheet just says it has "2 x 2dBi chip Antennas", vs. the 7711 USn saying it has one "3 dBi High-Gain rotatable & detachable antenna".
Oldjim
Resting Legend
Fixes: 63
That is the antennae which is part of the stick and the lead goes to the USB slot so you can move it away from the back of the computer
HPsauce
Fixes: 4
Quote: "This slim, outstanding and wireless USB adapter achieves the impressive performance when plugging in USB extended cable stand included within the packageWink
ejs
Aspiring Hero
Fixes: 25
You can put any wireless USB stick on a usb extension cable. I doubt it will be better than one with a proper (not internal) antenna.
HPsauce
Fixes: 4
Quote from: ejs
So do I, in fact I know it will be worse.
However, it looks as if flexibility/portability is also an issue, in which case USB may have some merits.
ReedRichards
Seasoned Pro
Fixes: 25
HP, you have never explained your strong preference for a PCI wireless adaptor and it only emerged some way into the discussion that you meant a PCI adaptor with a desktop aerial.  Why do you think a PCI adaptor is so much better?
HPsauce
Fixes: 4
My experience is that performance, signal strength, coverage/reception, reliability, resistance to damage etc. etc. are all much better with internal cards (be they in a desktop or laptop).
This is based on several years of experience with both.
(With laptops PC-card types are usually OK, but using a fully internal type with the laptops own inbuilt aerials if available is even better)
USB devices are prone to overheating and damage and going through the USB interface seems to frequently make them slower, and their aerials are usually not very good. The only variation I've never used is a USB device with a large attached aerial, as opposed to internal.
Sometimes, depending on orientation, having a directly-attached "stick" aerial on an internal PCI card isn't an issue, but I almost always replace them with a "pigtail" type desktop aerial unless one is supplied (which is often the case).
I only use USB network devices as temporary fixes these days.
Edit:
As it happens I was doing some testing just now, looking at channel interference on my local neighbourhood wireless networks.
I plugged a "good" USB adapter into the laptop I was using and checked the signal strength of my own network (2 rooms away) with that and the "onboard" mini-PCI card adapter that I had installed a few days ago. 15dB difference in signal strength!  Shocked
(and yes it was the USB adapter that was worse, and I did try lots of different orientations to ensure it wasn't shielded in any way)
Spruance
Just a quick update.
The Edimax EW7717-UN didn't arrive until this afternoon (Tues 16th Nov), whilst I was out, and having been tied up on something else this evening I have only recently gotten around to setting it up. I had some difficulties getting the software to install properly which turned out to be a conflict caused by Windows New Hardware Wizard, but I am now wirelessly connected to my Thomson 585v7 router albeit that the router and USB adaptor are all of 12 inches apart! Grin I wanted to get it up and running before moving the router downstairs to the test socket, which I have advised the PN Support people that I will do tomorrow (Weds 17th Nov) morning after fulfilling a pre-arranged appointment.
Perhaps not surprisingly I have 100% signal strength where the router is situated now, but I also found five other wireless networks via the scanning utility. I am actually quite impressed by that given that I am in a detached house. I know that the neighbours each side are online but the OAPs over the road certainly aren't which means that the other three WLANs that the adaptor can 'see' are at least 20+ metres away through two sets of cavity walls.
I can understand HP's reservations about USB adaptors but I don't see this as a permanent solution but rather as a back up option. If the connection to the test socket shows that I could get a vast speed increase by switching the router downstairs permanently then I will most likely get a PCIe card for the PC and might even consider the electrical wiring (Powerline?) option. I am just curious to see what transpires. If there is no improvement to be had at all then I will probably revert to the current hardwired ethernet arrangement but at least the next time PN need me to connect via the test socket, I will have the means to do so without being offline for the duration.
I will update this or the other thread as soon as I have something more to add.
Spruance
