upgrading to wireless n router, is it worth it?
nogginthenog
currently using thomson TG585 v7 router which works well with all my devices stats are:
Uptime: 0 days, 19:26:58
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 7,616
Output Power (Up/Down) [dBm]: 11.5 / 11.5
Line Attenuation (Up/Down) [dB]: 5.0 / 6.0
SN Margin (Up/Down) [dB]: 21.0 / 12.0
Vendor ID (Local/Remote): TMMB / ALCB
Loss of Link (Remote): 0
FEC Errors (Up/Down): 0 / 2,906
CRC Errors (Up/Down): 0 / 9
HEC Errors (Up/Down): 0 / 10
Recently upgraded laptop with wireless n network card, would i see any speed/performance increase
by changing to a wireless n router?
replies appreciated
9 REPLIES 9
HPsauce
Re: upgrading to wireless n router, is it worth it?
Only transferring data to other devices on your local network.
pierre_pierre
and it can severely muck up your neighbours see below
HPsauce
Grin Grin
Indeed. I see a similar picture at times.  Angry
Fortunately my neighbours are not too close.
ReedRichards
Seasoned Pro
Fixes: 25
HPSauce is correct but extremely succinct.  If your sync rate is 7616 kbps then your IP Profile should be 6500 kbps.  So 6500 kbps = 6.5 Mbps is the fastest download you could ever achieve.  A good strong wireless connection with wireless g should give you 54 Mbps so if all you are concerned about is broadband speed then the speed bottleneck is your telephone line running at 6.5 Mbps.  However if your computer is far from the router then you may not be getting the full-speed wireless signal.  Your computer should tell you how fast the connection actually is.  The number may vary but if it ever drops below 6.5 Mbps then you might benefit from a wireless n router.
chillypenguin
pierre, what software was that you were using for the screen shot?
HPsauce
Quote from: ReedRichards
Frequently.  Cool
HPsauce
Actually if it drops as low as 11mbps regularly you MAY benefit.
In reality wireless throughput is only a fraction (third, maybe half) of the connection speed.
HPsauce
Quote from: 565
Looks like Inssider 2.0 - that's what I use.
pierre_pierre
it was, but I have found, dont leave it on if you connect to router  via WiFi, if really slows you down
