No encouragement to upgrade?
- Re:No encouragement to upgrade?
05-11-2009 12:12 PM
Since my conversation I have read Jameseh helpful post - http://community.plus.net/forum/index.php/topic,80204.0.html
However, I don't feel encouraged to pay more for an upgrade to something that may not be of benefit
Re: No encouragement to upgrade?
05-11-2009 2:45 PM
http://www.kitz.co.uk/adsl/max_speed_calc.php
What was the £30 for?
05-11-2009 4:16 PM
your in that speed band where adsl2+ is not likely to make much if any improvment apart from the upload,
05-11-2009 4:33 PM
The £30 applies to the charge that we would incur to move you back to IPStream.
Your current speeds are unfortunately in the bracket whereby you may not see an improvement on ADSL2 and it's very difficult (read as impossible) to give you a guarantee of improved speed.
However, if you did want to move back to an ADSL service, we could just put you on the upto 8Mbps variant offered on the 21CN platform which should give you exactly what you're getting now.
06-11-2009 9:27 AM
Quote from: ASBO i thought as existing customers you had to upgraded to PRO or PREMINUM and request to be moved to adsl2+
Nope, PN have stated some legacy products will get the upgrade too, but they have not given a date for when that will happen nor the products that will be upgraded.
It should be Unlimited and BBYW would get the updates I think as it was talked about at the time. But that's my speculation only.
SW.
3Mb FTTC
06-11-2009 3:37 PM
06-11-2009 4:11 PM
3Mb FTTC
06-11-2009 4:27 PM
if they was going to use unlimited on adsl2+ why would they replace it with preminum, they kepted the other 2 packages
06-11-2009 4:55 PM
Quote from: ASBO if they was going to use unlimited on adsl2+ why would they replace it with preminum, they kepted the other 2 packages
I guess I was either lucky or unlucky depending how you look at it, I am on unlimited and ADSL2+ 21CN
John B.
06-11-2009 10:19 PM
Quote from: ASBO granted its on the unlimited page but it dosent seem as thoe its attached to that specfic product
It is/was attached to the pop up page which appeared when you clicked on 'More Info' from the main www.plus.net frontpage which advertised the PN Unlimited account.
SW.
3Mb FTTC
06-11-2009 11:09 PM
Quote I guess I was either lucky or unlucky depending how you look at it, I am on unlimited and ADSL2+ 21CN
So am I but I'm beginning to think Premium at 80GB is more than most will use and appears to have better shaping.
07-11-2009 12:51 PM
BT charge less for it and the the "up to 8Mbps" products can be speed-limited.
07-11-2009 1:06 PM
09-11-2009 11:05 AM
Ultimately (and I stress this is long term), I'd expect us to move our entire base to WBC & IPSC, be it on the 8Mbps or 24Mbps variant (WBC).
It makes sense from a cheaper tail cost aswell as the bandwidth being slightly cheaper, couple with the fact that we have greater flexibility over bandwidth increases.
12-11-2009 11:08 AM
