No apparent change in speeds
- Re: No apparent change in speeds
02-12-2009 9:38 AM
Sorry to resurrect this one but James’s last post suggested that if the line is stable that the SNR would reduce to its previous figure of around 6db with a corresponding increase in connection speed from the current 5.4 (ish) mb to (again) the previous figure of about 6.5mb. I have a very stable connection, broken only by an occasional reboot of the router by me, for close to 2 months, well over this 28 day threshold. As you can see by comparing my router stats for today (below) with my previous posts, there has been no reduction in SNR and no increase in speeds; are these changes made automatically or do I need intervention from Plusnet?
Rob
02-12-2009 9:44 AM
Have you checked in your routers detailed stats to see how many errors are being logged?
02-12-2009 9:56 AM
Quote from: Just The attachment is missing.
Oops Thanks Just for Barry. Where can I view the errors? My router is a Netgear DG834
Today's stats
AN PPPoA 14 14 0 46 54 00:00:20
LAN 10M/100M 240 330 0 1185 630 00:01:10
WLAN 11M/54M 0 0 0 0 0 00:01:00
ADSL Link Downstream Upstream
Connection Speed 4470 kbps 439 kbps
Line Attenuation 45 db 13 db
Noise Margin 12 db 20 db
02-12-2009 10:01 AM
02-12-2009 10:17 AM
I presume that high levels of errors are a consideration with my enquiry, and obviously I’ll investigate and report back, but I would also like a response from +net staff when they have a minute
Rob
02-12-2009 10:19 AM
When you have it running you need to look at the Telnet Router, Summary tab where you will find data like this:
Downstream (Rx)
Connection Rate: 8128 Kbps
Line Attenuation: 20 dB
Noise Margin: 9 dB
Interleave CRC: 0
Interleave FEC: 0
Interleave HEC: 0
Fast path CRC: 116
Fast path FEC: 0
Fast path HEC: 0
Superframes: 79191973
Upstream (Tx)
Connection Rate: 832 Kbps
Line Attenuation: 13 dB
Noise Margin: 15 dB
Interleave CRC: 0
Interleave FEC: 0
Interleave HEC: 0
Fast path CRC: 149
Fast path FEC: 0
Fast path HEC: 0
Superframes: 79195503
ATM Totals
Uptime (from SF Count):
15 days, 13:59:13
Upstream (Tx):
Good Cells: 12890816
Idle Cells: 2629010468
Downstream (Rx):
Good Cells: 65429965
Idle Cells: 4269077069
Bad HEC Cells: 111
Overflow Dropped: 0
Bytes Transferred (ppp0):
Tx: 166378190 (158.6 Mb)
Rx: 935667062 (892.3 Mb)
02-12-2009 10:28 AM
02-12-2009 8:26 PM
Connection Rate: 4470 Kbps
Line Attenuation: 45 dB
Noise Margin: 11 dB
Interleave CRC: 0
Interleave FEC: 0
Interleave HEC: 0
Fast path CRC: 401
Fast path FEC: 0
Fast path HEC: 0
Superframes: 2391425
Connection Rate: 439 Kbps
Line Attenuation: 26 dB
Noise Margin: 19 dB
Interleave CRC: 0
Interleave FEC: 0
Interleave HEC: 0
Fast path CRC: 0
Fast path FEC: 0
Fast path HEC: 0
Superframes: 2392604
0 days, 11:18:14
Upstream (Tx):
Good Cells: 1190543
Idle Cells: 41011909
Downstream (Rx):
Good Cells: 5176735
Idle Cells: 423897683
Bad HEC Cells: 362
Overflow Dropped: 0
Tx: 47309579 (45.1 Mb)
Rx: 238413356 (227.3 Mb)
02-12-2009 11:19 PM
Next time you reconnect could you look to see what the downstream noise margin is?
03-12-2009 9:44 AM
I re-booted the router every day, first thing, on going on to ADSL+2 for a period of about 3 weeks or so. The figures only had a small variation to them 4 to 4.7 mb downstream, always 439 kbps upstream with downstream SNR always 12db. TBH as this daily routine of re-booting the router had no effect I reverted back to my normal practise of leaving the router connected 24/7
Rob
03-12-2009 9:51 AM
Quote from: randpwar I reverted back to my normal practise of leaving the router connected 24/7
Could you explain this then please:
Quote Uptime (from SF Count):
0 days, 11:18:14
If you are getting odd disconnections not initiated by you that will be why the target isn't getting set lower.
03-12-2009 10:10 AM
Am I right in thinking that a solid connection like mine (see post below), and one that used to give me actual browsing speed of 5 to 5.5 mb, should return to it’s previous speeds or even increase as I’m now on ADSL2+?
http://community.plus.net/forum/index.php/topic,79278.msg645215.html#msg645215
03-12-2009 10:26 AM
I think it's supposed to be progress!
03-12-2009 10:32 AM
I haven’t had a drop in connection since whatever happened in the thread below. So, Plusnet staff, in the absence of ‘The Legend’ what can you do to help?
Rob
04-12-2009 10:54 AM
I think my request for advice from Plusnet staff has slipped through the net. Would someone please review this thread from reply 15 onwards and advise accordingly
Ta
Rob
