No Internet
- No Internet
No Internet
30-10-2020 9:23 AM
I had my phone line at my workshop reconnected a few months back but the internet has never worked. I have tried what is suggested on the Plusnet site but I don't have a landline to plug in or another router. I haven't been able to get to my workshop much so haven't worried but am paying for internet which has never worked. I tried to call Plusnet but was just on hold so had to give up as I had work to do. The Power, broadband and WiFi lights on the router are green and the internet is red. Is this likely to be a problem at my end or with the service?
Message 1 of 2
(307 Views)
1 REPLY 1
Re: No Internet
30-10-2020 12:50 PM
Hi @MitchBell
Given the long wait times when calling Plusnet I recommend you would follow the online troubleshooter using mobile data to connect to the web site.
Depending on the results of the process a fault ticket will be raised with Plusnet.
I also recommend you but or borrow a landline phone to aid the troubleshooting.
It is useful to prove that you actually have a phone line connection and to test for noise on the line.
A landline phone is not expensive to buy.
For example: https://www.argos.co.uk/product/5529610
Regards
Richard
Message 2 of 2
(278 Views)
