No Broadband
DylanFan3
No Broadband
I disconnected my ADSL filter in order to test another filter, I then couldn’t connect to the internet,? I swapped the filter back so the cables were exactly as before and still no internet, I despair at what can be wrong, anyone????Huh
2 REPLIES 2
Crazycat
Re: No Broadband
Mine has been off since around 4 30pm . Apparently there's a fault when we called, although its not showing on any service issues online. Customer service closed until tomorrow, I'm sure they will be getting plenty of calls first thing.
Legend
Fixes: 219
Re: No Broadband
@DylanFan3 How far can you get towards a connection before it fails - i.e. what lights are on your router and what are they doing?
@Crazycat  Your issue is totally different, and you should have started your own topic - high-jacking someone else's is bad practice and makes it difficult for anyone to help.
