New to Plusnet Fibre - Slow Speeds
- New to Plusnet Fibre - Slow Speeds
- « Previous
- 1
- 2
- Next »
Re: New to Plusnet Fibre - Slow Speeds
24-11-2013 4:40 PM
In normal circumstances you would just think that my profile had been locked but both Plusnet support and BTOR tell me it has been provisioned correctly. The really worrying thing is that the BTOR engineer fixes a clear line fault and nothing improves, if anything it gets worse. My only hope is that this does prove to be a problem with the ports in the exchange otherwise I fear this will be an undoing issue with no clear solution.
Message 16 of 19
(243 Views)
25-11-2013 11:23 AM
OK I have been trying to be patient but I would really like to know what the next step is from Plusnet with the ticket associated with this post.
Message 17 of 19
(243 Views)
25-11-2013 1:14 PM
I can see that our Faults Team are due to get back to you today. I've updated your Speed Profile though so it should just be a case of you logging into your router hitting 'Disconnect' and then 'Connect' again for the changes to take effect?
Message 18 of 19
(243 Views)
25-11-2013 4:48 PM
Chris,
Thank you so much. I have just run a speed test and got 72mbs downstream. I am so happy that this is finally resolved as I was beginning to think this would be an ongoing problem.
I have not heard anything back from the fault team but I will close the ticket anyway.
Thank you again.
Thank you again.
Message 19 of 19
(243 Views)
- « Previous
- 1
- 2
- Next »
