Replacement Fibre Router
wilbywanderer
I am about to purchase a replacement router for the one supplied by PN. Thinking of the Netgear R6300 router (new AC standard) my question is -will I have to enter a user ID and password to connect the router to the internet ? I suspect the answer is yes - can I assume the user ID is in the format (username) @plusdsl.net and the password is my usual PN password ?
Any tips on the R6300 router would be much appreciated
Fixes: 65
Re: Replacement Fibre Router
Yes, you would need to enter a username and password in order to authenticate, it's the main account password and the username should be in the format you mentioned.
Adam
 Adam Walker
wilbywanderer
Very many thanks for your swift response - much appreciated  Smiley
