New router installation problems
- New router installation problems
- « Previous
- 1
- 2
- Next »
Re: New router installation problems
15-09-2012 7:07 AM
Ah ha! trying to find it in the wrong place, trying to find it in the PC based settings of the printer, should be looking in the printer itself.
Thanks again ReedRichards.
Message 16 of 19
(294 Views)
17-09-2012 10:14 AM
By Friday last the new router (Netgear N300) was working just Ok, but I noticed it was a lot slower than the old one (Netgear DG834G) But I noticed throughout Saturday and Sunday the connection speeds were gradually speeding up, by today (Monday) it is ferociously quick.
My initial thought that was by coincidence PN were having problems over the weekend(?) but I didn't notice anyone else complaining about it. So I wonder, do new routers have a settling in period before reaching design or line compatible speed?
I never mentioned why I changed the router in the first place; the old one needed to be re-booted up to 4 or 5 times a day more if I was home all day, and it ran very hot, not just electrical appliance warm but very hot to touch (there are/were no ventilation issues) indeed I was quite wary about going out and leaving it on.
The new router not only is faster but is agreeably cooler to the touch. It does though appear to be designed to be mounted on its vertical stand rather than flat on a shelf (as the old one was) Is there really a reason for this?
Message 17 of 19
(294 Views)
17-09-2012 11:51 AM
Did you take the old one apart to see if it was clogged up with dust inside?
Message 18 of 19
(294 Views)
17-09-2012 12:41 PM
The DG834G is equipped with a multitude of vent holes presumably indicating some heat is normal , with its LED's on the case is almost translucent (white) no dust could be seen. In use the router lives in an area that is well ventilated and usually pretty dust free (yes! no such thing I hear you shout) But to be honest, I didn't strip it down and clean it.
Message 19 of 19
(294 Views)
- « Previous
- 1
- 2
- Next »
