New fibre connection - slow speeds
EddieR
My fibre connection went live earlier this week but the speeds seem considerably slower than they should be.  I've read that it can take 10-14 days for the speed to settle, but at the moment it seems to be running at about half speed and even slower than the guaranteed minimum. My package should be close to 71Mbps but the speed test is giving me results of around 30.
Checking the status on the Hub Two shows the downstream sync as 36, is that normal for a new connection?
Plusnet fibre package - Estimated download speed: 71Mbps
BT Wholesale speed test
Plusnet Hub Two Manager - Status
Connection type:  Fibre Broadband (VDSL)
Downstream sync speed:  36.284 Mbps
Upstream sync speed:  4.006 Mbps
18 REPLIES 18
Fixes: 334
Re: New fibre connection - slow speeds
@EddieR Can you post the 'Broadband' and 'Technical Log' pages from your Hub, please - obscuring personal details.
EddieR
Broadband
Connection status:  Connected
Downstream:  36.284Mbps
Upstream:  4.006Mbps
Connection information
Connection time:  0 Days 1 Hr 40 Mins 10 Secs.  (I tried restarting the router this morning to see if that would help - it didn't)
Data usage:  112.6 MB Uploaded / 1.4 GB Downloaded
Product name
Plusnet Hub Two
Serial number
+R91300+2043013335
Firmware version
v0.10.00.04201-PN (Thu Apr 20 16:54:19 2023)
Board version
R01
GUI version
1.9 16_08_2022
DSL uptime
0 days 7 Hours 40 Mins 53 Secs
Data rate
4.0 Mbps / 36.3 Mbps
Maximum Data rate
4.0 Mbps / 37.5 Mbps
Noise margin
6.1/6.4
Line attenuation
10.5/17.4
Signal attenuation
10.5/19.8
VLAN id
101
Upstream error control
Off
Downstream error control
Off
Data sent / received
112.4 MB Uploaded / 1.4 GB Downloaded
Broadband username
2.4 GHz wireless network name
2.4 GHz wireless channel
Smart (Channel6)
5 GHz wireless network name
5 GHz wireless channel
Smart (Channel36)
Wireless Security
WPA2 (Recommanded)
Wireless mode
Mode 1
Firewall
On
MAC address
Software variant
Boot loader
0.1.7-PN (Thu Nov 30 09:45:22 2017)
Fixes: 334
The full 'Broadband' page would be useful, although it does appear you are connected at 40/10. I also note that you have uploaded a massive amount in a short time - that will not help your download performance.
EddieR
Here's the full broadband info, although there's not much extra info other than the gateway and DNS info.
Are you reading the correct upload/download?. I don't think an upload of 112Mb would classify as "massive" these days 🙂
Fixes: 124
@jab1
Not sure 112.4 MB Uploaded is considered a massive amount of data
Edit:
@EddieR
Which package have you signed up for 'Fibre' ? It looks more like Unlimited Fibre 40/10
Fixes: 531
The speed isnt being limited by a 40/10 profile, if it was it would sync at 39.999. It's not reaching that, therefore its being limited by (perceived) line capability. If the minimum guaranteed speed really is 71Mb then @EddieR needs to raise a fault (except that a fault can't be raised to Openreach in the 1st 10 days!!)
Fixes: 334
@Dan_the_Van Sorry - trying to juggle too many balls today. @EddieR - ignore that comment.
Fixes: 334
@MisterW After careful consideration 😉 , I agree, but there is nothing in the supplied data to suggest what it may be,
Fixes: 531
Agreed!. Perhaps @EddieR could post the results from the BTwholsale checker (https://www.broadbandchecker.btwholesale.com/#/ADSL) redacting any personal details, so we can see what the estimates are ?
Also , is the router connected to the master socket ?
is it the latest NTE5/Mk4 ?
are there any wired extensions ?
EddieR
@MisterW  Yep, it's connected to the master socket (annoyingly located in the bedroom). It's an older MK2 socket, and there aren't any wired extensions or even anything else plugged into the router at the moment.
The Plusnet package says it should be anywhere from 50-71Mb fibre, with minimum gaurantee of 44.6Mbps.
and here's the BT wholesale details.
Fixes: 334
@EddieR Report a Broadband fault - you are below the hand-back threshold, even for an impacted line.
Fixes: 531
@EddieR assuming you mean the master is one of these https://www.run-it-direct.co.uk/bt-line-boxes-and-sockets/nte5cmastersocket/
you could perhaps try removing the lower faceplate and connecting to the test socket. Then check the broadband page on the router to see if the speeds have changed
If that doesnt make any difference, then it would appear to be an external line problem. I'm afraid you're going to have to wait until the 10 day 'training' period is up and then raise a speed fault citing its below MGALS.
Fixes: 334
@MisterW I thought FTTC didn't have the 'training' period, or is that just FTTP?
Fixes: 531
@jab1 Correct, FTTC doesnt really have a training period but it does have a DSLAM to control the line performance and as such its always been claimed/accepted that speed faults cant be raised to OR in the first 10 days.
FTTP doesnt have any DSLAM , speed is only controlled by the profile of the product e.g FF74. It either goes at the profiled speed or not at all!
