New fibre connection - slow speeds
- New fibre connection - slow speeds
- « Previous
- 1
- 2
- Next »
Re: New fibre connection - slow speeds
08-12-2023 1:57 PM
Thanks for all the suggestions so far!
I've tried the test socket and I still get the same speeds, so it seems I'll have to make do for a few more days and report the fault as soon as I can once the 10 days are up.
08-12-2023 2:07 PM
For me this is not a fault, a fault would suggest it worked correctly at one time and something has gone wrong, where this is never worked as expected from the start.
Is the broadband username yours or setup@plusdsl.net? It might be worth a factory reset on the Hub to see if this prompts the management system to correct the connection.
Push a paper clip in the hole at the back of the Hub until the lights go out.
08-12-2023 2:13 PM
@Dan_the_Van technically you're right! However being below MGALS is classed as a 'speed fault' rather than a non-functional fault and AFAIK OR won't accept that until the 10 day period is up.
08-12-2023 2:45 PM
@Dan_the_Van Yep, it displays my username.
I tried a factory reset, and saw the username change from an initial setting of setup@ back to my username after a few minutes - but still no joy.
- « Previous
- 1
- 2
- Next »
