New broadband connection. Orange light
Fixes: 334
Re: New broadband connection. Orange light
OK - over to you, @Mustrum 😀
Sweep
When I click connect...it thinks then it goes green at the connect button and says disconnected, with a tick!
Mustrum
Fixes: 81
@Sweep  have you been told your account has gone live? Have you had a txt and/or  email?
Does your old router still work?
Fixes: 334
Strange, but as I say, I'm not a PN customer any more, so I won't muddy the water any more with my next suggestion
Sweep
Hi. Yes I got the texts yesterday. Wasn't working last night so I left it till today. My old connection has now gone, but the router physically works
Sweep
I've just re read the texts. Said phone connected and broadband will follow any time up to midnight. We will send a follow-up communication to confirm this.....that I haven't had.
Sweep
The connection status on the hub page says no service
Fixes: 334
@Sweep Sounds like the Broadband setup failed for some reason at Plusnrt. I suggest you try ringing them tomorrow - it should have gone live by midnight of your connection day,
Sweep
Thanks john. Hoping they're open tomorrow!
Fixes: 334
They are. 😉
Sweep
Oh. Just called the 0800 number and it said 9-5 Saturday, no mention of Sunday?
Fixes: 334
So far as I am aware, the service is available 7 days a week, but maybe @Mustrum can confirm?
Fixes: 529
From the website https://www.plus.net/contact-us/ it's 8 till 8 Mon -Sun
Sweep
Oh I've tried to call about three times. It says they're busy. Then it says our provisioning dept is closed. Call 8-8 Monday to Friday and 8-5 Saturday. Am I using the wrong number? It's the one on the link you posted I'm using.
Fixes: 334
Ah! Provisioning- I don't think they work Sundays, so it may be Monday before you can call them, but there may be other areas that can help tomorrow. Don't ask me which though, it's a while since I had dealings with PN and I know there have been changes since I  last had to call them about two years ago.
