New Customer put on ADSL rather than ADSL2
- Re: New Customer put on ADSL rather than ADSL2
04-02-2013 11:06 AM
Migrated from Bethere last week to Plusnet Unlimited ADSL. On Bethere I was on ADSL2 but I appear to be on ADSL at the moment with a lower speed. I have requested my upload to be uncapped but do I need to request a regrade as I should be on ADSL2?
Message 1 of 8
(1,549 Views)
7 REPLIES 7
04-02-2013 11:38 AM
Have you checked that your exchange has the capability - LLU ADSL2 does not equate to BT ADSL2? http://www.samknows.com/broadband/exchange_search
Can you post the stats from your router - Sync, Noise margin etc?
Plusnet FTTC (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
Message 2 of 8
(599 Views)
04-02-2013 3:44 PM
Hi danivtec,
Just placed an order to move you onto ADSL2+, it should complete tomorrow
Please let us know how it goes, thanks.
Message 3 of 8
(599 Views)
04-02-2013 5:58 PM
Thanks, I will let you know.
dick:quote
dick:quote
Message 4 of 8
(599 Views)
06-02-2013 9:45 AM
This has transferred over and speed has increased including upload.
SNR is at 9db at the moment, will DLM change this during the training period?
Message 5 of 8
(599 Views)
06-02-2013 1:23 PM
I'm not convinced it will to be honest, I suspect it might need an SNR reset to do that - though I'm not convinced at present that that's the best idea. It's stayed up for over 24 hours now but I'd rather wait until tomorrow if that's alright? If it stays up overnight then we'll get the reset done and set the downstream target SNR to 6dB for you.
Message 6 of 8
(599 Views)
06-02-2013 2:39 PM
Hi
Yes thats fine.
I had a 3db profile on my previous ISP with no problems.
Yes thats fine.
Message 7 of 8
(599 Views)
07-02-2013 10:24 AM
Hi @danivtec,
The connection has stayed up overnight, despite a disconnection around 2 hours ago. However I've put that SNR reset through for you so hopefully you should notice the effect of that soon.
Message 8 of 8
(599 Views)
