New Customer - Fibre Banded
mobymatt
Re: New Customer - Fibre Banded
Thanks for trying, John.
Fixes: 579
That looks suspiciously like the line's been provisioned in error on a 40/10 profile.
As @jab1 says, it needs staff input, I'm sure one of the help team will be along shortly...
LaurenB
Fixes: 131
Hiya @mobymatt, thanks for getting in touch!
I'm sorry for the issues with your speed. I've had a check over this and you do look to be provisioned correctly and testing hasn't detected what may be causing this, but your line is banded.
I have logged a fault here for you: https://www.plus.net/wizard/?p=view_question&id=224759220 and sent off a request to have the banding lifted for you, please just allow 3 working days for this to take effect.
 Lauren Barry
mobymatt
Hi Lauren.
Thanks for looking at this for me. I have just witnessed a line drop, and these are that stats on the Technical Log...
DSL uptime:0 Days 0 Hrs 2 Mins
Data rate:10.387 Mbps / 50.152 Mbps
Maximum data rate:10.387 Mbps / 49.019 Mbps
Noise margin:6.1 / 6.1
Line attenuation:9.0 / 19.1
Signal attenuation:9.0 / 25.3
Not sure if it will move up from this, but better than before. 🙂
Thanks to everybody for helping.
Fixes: 382
@mobymatt I reckon, based on the attenuation figures reported, that you should be getting better than that - hopefully, @LaurenB 's action will improve things.
mobymatt
Has been a promising start.
LaurenB
Fixes: 131
My colleague actioned the request for you and I've just tested and can see the sync has already gone up, let us know how things go!
 Lauren Barry
