Network Down
rooky
Network Down
My router is flashing orange and I done the text for help and they said it down. But I keep
Getting phone calls from plus net but I am deaf so can't take the calls.
Can you pls email me tell me how long this will take to solve. As are you sure it a network issues as next door got internet
3 REPLIES 3
Gel
Champion
Fixes: 29
Re: Network Down
rooky
Re: Network Down
If only I can find it as they taken it down
Re: Network Down
@rooky  you probably don't want to use @Gel's link to  PN Network Status  as it appears to NOT be a Plusnet managed website and for me produces the browser warning shown below !  🙄
Instead, you can check for internet problems in your area by either putting your full landline number, or landline area code, in to the  Zen Broadband Status  checker.
