Contact by email or at least an international number?
crdfox
I am abroad and need to contact customer services but there is no email I can find and the number only works within the UK. Is there an email I can use (ideally) or at least a number I can call from overseas to get through to customer services?
Cheers
Charlie
4 REPLIES 4
Fixes: 337
Re: Contact by email or at least an international number?
+44 345 140 0200
crdfox
Nice idea but 034455 number do not work from outside the UK!
Fixes: 337
They do - if you use them as international codes - i.e. if you were calling the U.S. from the UK for example, '001xxxxxxxxx' would work. I don't know the code to access the UK from wherever you are - try asking.
Fixes: 128
The international dialling code for the UK is +44 or 0044 if you phone number pad does not have a +
 For any phone number the leading 0 is replaced with either 0044 or +44 for the UK, France would be 0033 or +33
So you would dial either 0044 345140 0200 or +44 345 140 0200
HTH
