Netgear or Thompson Router
- Re: Netgear or Thompson Router
03-02-2011 2:45 PM
I have just come back to PlusNet after a year away. With the order i got a Thompson Router. I currently have a Netgear DG834G router. Should I use the one supplied by PlusNet or stick with my Netgear? Cheers.
03-02-2011 2:48 PM
05-02-2011 6:35 AM
One thing I did notice when I temporarily used the Thompson was how many more wireless network connections it picked up in my street.
05-02-2011 9:58 PM
Simples!
06-02-2011 9:06 AM
06-02-2011 11:01 AM
Quote from: Oldjim if you are happy with it stick with the Netgear assuming it is a v4 with the Broadcom chip
Is there an issue with v3 routers of that model ?
06-02-2011 4:06 PM
The earlier ones have the AR7 chipset and the v5 has a Conexant CX94610 chpset
06-02-2011 4:47 PM
06-02-2011 9:18 PM
Personally I'd be inclined to do it to remove any doubts.
06-02-2011 9:32 PM
I would say, definitely stick with Netgear, they are a well established networking brand. Thompson are an electronics brand, building a huge range of products, none of which excel over other brands. Eg, A Thompson Sky box will be less reliable than a Pace one, I know this because I used to install them.
06-02-2011 11:50 PM
How do you install the latest firmware for this model
07-02-2011 12:05 AM
