Netflix streaming problems since Friday evening (2nd May)
- Re: Netflix streaming problems since Friday evenin...
- « Previous
- 1
- 2
- Next »
Re: Netflix streaming problems since Friday evening (2nd May)
07-05-2014 12:43 PM
07-05-2014 12:50 PM
Ta.
08-05-2014 11:17 AM
08-05-2014 11:37 AM
Things seem to be improving somewhat.
09-05-2014 12:18 PM
09-05-2014 5:06 PM
Would you mind if I tried you on a different policy to see if I can get this sorted out for you? You won't need to do anything, it will just require me to place an order from our back end systems to see if we can get the quality issue sorted out?
09-05-2014 5:11 PM
09-05-2014 5:12 PM
I'll get the order placed and see how we get on. You are unlikely to notice any difference until Tuesday though.
16-05-2014 3:45 PM
16-05-2014 3:52 PM
16-05-2014 4:17 PM
29-05-2014 8:50 PM
As a last resort I reset the LG TV back to the factory settings which I really didn't want to have to and I'm still trying to get the picture settings back to how they were but it instantly cured the streaming issues, what I couldn't stream for 5 minutes with it pausing or stuttering just half and hour before played with no issues after the reset. It's been fine since.
The TV is an LG 42" 3D Smart TV from 2013 . Not sure of the model number. It had been going about 15 months before streaming became an issue.
Thanks for all your help and suggestions.
- « Previous
- 1
- 2
- Next »
