Router recomendations
I am about to ditch my second TP-Link router as the 2.4Ghz keeps disappearing.
Can anyone suggest a replacement router.
I am looking for the following specs.
2.4Ghz
5 Ghz.
2 usb ports.
ac if possible.
Sadly money is an object :-)
Approx £80 ish.
podman
gwillym
Re: Router recomendations
I'd recommend the BT Home Hub 5 EXCEPT its only got 1 USB port  Sad
got mine from a well known auction site for £55
Fixes: 127
I think getting the 2 USB ports will be an issue Sad
Will Moderate For Thanks
You could probably connect a USB hub to it.
I opted for the Asus n56u in the end.  Great reviews and quite good looking router.
Going home to set it up.
I've been using mine for 18 months. It's absolutely brilliant, incredibly fast & totally reliable. Asus are obviously happy that they have it sorted because the frequency of firmware updates has decreased enormously.  Smiley
