My Broadband speed has been bad since Christmas
- Re: My Broadband speed has been bad since Christma...
03-01-2011 7:31 PM
I have been with Plusnet for nearly 8 years - and it has never been this slow.
According to the BT speed test my current stats are:
Download speedachieved during the test was - 129 Kbps
For your connection, the acceptable range of speeds is 50-250 Kbps.
Additional Information:
Your DSL Connection Rate :1536 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 135 Kbps
Any idea what this means? If I go through Support the system wants me to buy new micro-filters, routers etc... I am not spending money until I know there is a problem and I am pretty sure these are all good. The figures above suggest I should be getting 1.5Mb download - not 129Kbit.
Interestingly my upload speeds are faster - around 300Kbps.
Any ideas?
Thanks,
Wayne
Re: My Broadband speed has been bad since Christmas
03-01-2011 8:25 PM
a) what package are you on?
B) if it is one of the old packages - have you approached your Mb limit? https://portal.plus.net/view_my_broadband_usage/index.php
c) can you post your router stats instructions here http://www.kitz.co.uk/adsl/frogstats.php
03-01-2011 8:39 PM
Quote a) what package are you on?
Broadband Plus up to 8MB. I have been on this since 2004.
Quote B) if it is one of the old packages - have you approached your Mb limit? https://portal.plus.net/view_my_broadband_usage/index.php
My last months usage is under 6GB. I have been higher with this with no issues before.
Quote c) can you post your router stats instructions here http://www.kitz.co.uk/adsl/frogstats.php
adslctl: ADSL driver and PHY status
Status: Showtime Channel: INTR, Upstream rate = 448 Kbps, Downstream rate = 1536 Kbps
Link Power State: L0
Mode: G.DMT
Channel: Interleave
Trellis: ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 13.0 16.0
Attn(dB): 61.5 31.5
Pwr(dBm): 17.7 12.3
Max(Kbps): 1696 876
Rate (Kbps): 1536 448
G.dmt framing
K: 49(0) 15
R: 16 4
S: 4 4
😧 8 8
ADSL2 framing
MSGc: 1 1
B: 49 15
M: 4 4
T: 1 1
R: 16 4
S: 4.3200 4.2500
L: 400 128
😧 8 8
Counters
SF: 4943643 4943641
SFErr: 251 38
RS: 84041934 84041897
RSCorr: 6736 24
RSUnCorr: 1640 0
HEC: 225 30
OCD: 3 0
LCD: 0 0
Total Cells: 304454675 0
Data Cells: 2104068 0
Drop Cells: 0
Bit Errors: 0 0
ES: 122 0
SES: 0 0
UAS: 10 0
Total time = 23 hours 15 min 58 sec
SF = 4943643
CRC = 251
LOS = 0
LOF = 0
ES = 122
Latest 1 day time = 23 hours 15 min 58 sec
SF = 4943643
CRC = 251
LOS = 0
LOF = 0
ES = 122
Latest 15 minutes time = 58 sec
SF = 3412
CRC = 0
LOS = 0
LOF = 0
ES = 0
Previous 15 minutes time = 15 min 0 sec
SF = 52930
CRC = 1
LOS = 0
LOF = 0
ES = 1
Previous 1 day time = 0 sec
SF = 0
CRC = 0
LOS = 0
LOF = 0
ES = 0
15 minutes interval [-30 min to -15 min] time = 15 min 0 sec
SF = 52989
CRC = 0
LOS = 0
LOF = 0
ES = 0
15 minutes interval [-45 min to -30 min] time = 15 min 0 sec
SF = 52872
CRC = 2
LOS = 0
LOF = 0
ES = 1
15 minutes interval [-60 min to -45 min] time = 15 min 0 sec
SF = 52989
CRC = 0
LOS = 0
LOF = 0
ES = 0
dick:green Quote tags fixed.
04-01-2011 10:59 AM
[quote=rowley96] IP Profile for your line is - 135 Kbps
This result from your speedtest shows that it is not to do with your package, as that would not affect the BT profile. It now seems to be up to 1250 on our side as well as BT so you should be seeing that now.
Jojo
04-01-2011 5:18 PM
I'm sorry to say that is not the case at my end! My speed tonight is even slower...
Download speedachieved during the test was - 87 Kbps
05-01-2011 12:46 PM
It seems there is an inconsistency between the DSLAM and the B-RAS. I'll try resetting it first to see if that works and if not we'll have to raise a fault. I'll let you know when I have more information.
Jojo
05-01-2011 3:55 PM
I think the reset has worked but if you can run a BT speed test we'll be able to see if it has improved your throughput.
Jojo
05-01-2011 4:14 PM
Many thanks,
Wayne
05-01-2011 4:54 PM
Thanks, I'll try to have a look see if you've posted later from home.
Jojo
05-01-2011 5:12 PM
Download speedachieved during the test was - 69 Kbps
Your DSL Connection Rate :2656 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
Still slow, and still has the low IP Profile - but the DSL connection rate itself has increased.
Any thoughts?
Wayne
05-01-2011 5:16 PM
The sync rate has gone up because we've forced the SNR down. It certainly seems like the profile is stuck. I will raise a ticket over to our faults team for them with details of the profile inconsistency rather than get you to raise a fault.
Jojo
05-01-2011 5:45 PM
10-05-2011 6:56 PM
I have the same problem as I did in January... line speeds of 240K download & 376K upload. I can't play any video and web sites are very slow. It has been like this since Saturday. I can't seem to use the BT speed checker any more - they have changed it and it no longer works for me (Safari on a Mac).
Could you check the line again please - I had a definite fault last time.
Thanks,
Wayne
11-05-2011 11:22 AM
Having just tested your line I can see that both the PN & BT profiles are set to 1750k. A couple of suggestions... Have a look at our speed help guide. How is your kit set up? Are you using any extension cables/sockets? Have you tried the test socket? Are you getting these results wireless or via ethernet cable?
Jojo
11-05-2011 7:33 PM
I too have found my line speed has dropped since Christmas, in fact during the last few days it has dropped even more, i am now at the mind blowing speeed of 350kb yet my up speed is at 380kb.
Today the whole service went down for a while so i changed line filter as i keep spares, (it went off just before i got to this web site)
I recived notification from plus net that a new system 21CN is now available & i can get uo to 8 megs i don't think so in this one horse village
regards
Tel1749
