Multiple connection drops over the past 24 hours
mada
My connection is normally rock solid but over the past 24 hours the connection has dropped at least 4 times. Can someone look in to this please?
5 REPLIES 5
mada
Re: Multiple connection drops over the past 24 hours
Unfortunately my connection has gone down multiple times again this morning. This forum has always proved a great way for me to source help and get issues sorted. Is it still the quickest way for someone to run a few tests to figure out what's wrong?
mada
@James30 are you able to help please?
James30
Fixes: 26
@mada - Sure I can run a few quick cheeky checks. No worries. Something isn't right, have a look at http://visualradius.plus.net/visualradius/generated/image16845688753778.png, can I check are you leaving the router turned over night?
James - Plusnet Sheffield
mada
Yes always left on, never switched off. I called support yesterday and they are looking in to it further
James30
Fixes: 26
@mada - No worries keep an eye on https://www.plus.net/wizard/?p=view_question&id=233968308 for more progress updates.
