Move to adsl2+ please
FIXED- Subscribe to RSS Feed
- Move to adsl2+ please
14-05-2021 3:10 PM
My broadband went live today, unfortunately there was no fresh reset and I’m still on g.dmt from last supplier.
I have always found the most stable to be adsl2 .
I do however believe I am on 21cn.
Can I request to be switched to adsl2+ With a fresh retrain, then I can modulate to 992.3 on my router. Thanks
Fixed! Go to the fix.
Re: Move to adsl2+ please
14-05-2021 5:33 PM
Welcome aboard @warren18a
I've placed an order to move you onto ADSL2 now which should go through on Monday next week.
It looks like we've provisioned you on ADSL1 over BT's 21CN infrastructure due to far you are from the exchange, being on ADSL2+ isn't always better for long lines because of the higher broadband frequencies that it uses.
I've also done a full SNR reset of your line. Could you power down your router for 30 seconds in around 4 hours time? Once it's back up again you'll be in a 10 day training period.
Let us know how you get on
14-05-2021 5:41 PM
Thanks very much for that, very much appreciated.
Indeed your correct, in the past the 2plus hasn’t been great, but I found that adsl2 (992.3) always worked best on my line, same frequency as g.dmt but better correction etc. Best of both worlds really.
I can just uncheck adsl2+ on my billion to force adsl2. Worst comes to worst, I can force back to gmt as well
Again, thanks a lot 👍
14-05-2021 5:43 PM
15-05-2021 1:06 AM
One thing I did notice that I never had to this extent before is a very high CFC/es rate, if you had a minute maybe you could run your eye over it? Haven’t noticed any issues, just afraid of DLM having a fit .
I have no extensions or bell wire, straight in master. Have tried two routers and two different filters and getting same result.
Cheers
15-05-2021 1:14 AM
15-05-2021 12:02 PM
Yeah I noticed the very high error rate yesterday. Who was your previous provider out of interest? If they used their own equipment at the exchange whereas we use BT's, that may be where the issue lies so we might need to raise a fault and arrange an engineer visit although the line's in a training period so DLM may resolve the errors
Let us know how your connection looks next week once you're on ADSL2+
15-05-2021 12:11 PM
Only used to have about 20es a day, now in the thousands. Nothing has changed in the house. So am assuming must be a fault between exchange and myself somewhere. Long crappy country lines , a regular Occurance
Just don’t want dlm to have a fit, not noticing any problems with performance on my devices.
I had read on another post about a ‘custom profile’, maybe locking it at 6snr with heavy interleaving and change the error threshold to a stupidly high figure, so dlm won’t bother to intervene?
I’m out in the sticks so faults quite regular occurance, handier if dlm doesn’t bother.
Sorry for all the hassle, just I’m inside my 10 day cancellation so was trying to get all sorted before it runs out
Cheers, much appreciated
15-05-2021 12:27 PM
Ah that makes it even more odd although not odd in the sense that the line's long, on the bright side good views out in the country? I'm stuck in a city (Sheffield, and I say stuck, I love it) although we do have the peak district nearby.
Upon placing the modify order to ADSL2+ while I didn't set a custom threshold I did leave interleaving on as automatic and increased the stability profile from the standard/speed one to a stable config. I can set a custom threshold if we need to.
No problem at all, I'd recommend raising a fault to us at faults.plus.net if there are still errors or other issues come next week and we'll arrange an engineer visit. I'm out of the office on the 17th and 18th but one of my colleagues should hopefully be able to get back to you here in my absence if needed.
Cheers
15-05-2021 12:37 PM
That’s grand, we’ll see how the goes 992.3 goes and can raise a fault if needed. I know last time lightening had struck a pole down the road.
Cheers for all the help, your a gent 👍
15-05-2021 12:48 PM - edited 15-05-2021 12:48 PM
17-05-2021 9:41 AM
Hi all,
So just an update on what’s happening now.
The switch to adsl2 occurred last night and now getting zero errors! I don’t know if a setting was off or something before because over the weekend was getting 2000 errors seconds an hour! Whatever openreach done has fixed the error issue, not getting any crc or es at all now 👍
The only problem is, since there was tens of thousands of errors all weekend and drops connection during the training period, dlm has now increased the snr to 10 down, killing a lot of speed.
I was wondering if possible could you guys kindly reset me again to get the snr back to normal , now I have a nice clean error free line. Will give the line a chance to train properly now the errors have all disappeared .
Thanks alot
17-05-2021 11:32 AM
Thank you for reaching out.
I've had a look into the line configuration on our end and it appears to have been configured correctly, based on your line speed and stability.
Saying that, I've decreased the downstream SNR ratio down to 6dB in the hope of increasing your speeds.
Please let us know how you get on, and we'll be happy to help.
-Adam - Plusnet Leeds
17-05-2021 11:39 AM
Cheers Adam , when is the change likely to take effect?
17-05-2021 12:19 PM
Hey @warren18a,
The change should take place over the course of the next few hours, but it's best to keep an eye on how things perform over the coming days. If you notice any issues, just drop us another message on here and we'll be happy to help out.
