Manual SNR Target Please
- Re: Manual SNR Target Please
- « Previous
- 1
- 2
- Next »
06-02-2008 10:27 AM
Unfortunately not.
There's something called the DMT Tool which works on some routers, allowing you to force a specific target SNR. Unfortunately it doesn't work on Voyager kit.
I'll have a look at your ticket now.
Message 16 of 24
(446 Views)
06-02-2008 10:30 AM
James, the DMT tool does work on the Voyager 2110 which is how I was able to change the training target...
The problem is, the custom training target is only help in memory so when the router is powered down, it forgets
Thanks mate, appreciate it!
Message 17 of 24
(446 Views)
06-02-2008 10:41 AM
Cheers
Do you mind not using the tool for the duration of the fault? Otherwise BT will probably look at your SNR and think, oh, it's 9dB.
Message 18 of 24
(446 Views)
06-02-2008 10:44 AM
James, thanks... thought about that this morning so switched router off.
Can you help clear the below up?
BT set a target SNR of 15db for whatever reason.
I use DMT to force a 9db SNR and line remains stable for say, a week.
I reboot router which loses the forced 9db SNR and it reverts back to the BT set SNR 15db
How come BT's systems do not see that the line has been stable at 9db and automatically adjust the BT target?
Cant figure it?
Cant figure it?
Message 19 of 24
(446 Views)
06-02-2008 6:29 PM
Not sure if PN have done something or if taking the router down for about 6hrs helped it but on reboot, I've connected at the usual speed and SNR target
Maybe the above I wrote does work after all!
Anyway, will close the ticket
Message 20 of 24
(446 Views)
07-02-2008 9:13 AM
Blimey. This has got to be a first.
"15 - profile has now been changed to 9F as requested.....please reset after 2 hours"
I'm going to be in shock for the rest of theday week year.
Message 21 of 24
(446 Views)
07-02-2008 9:20 AM
Awesome, cheers mate. Now all they gotta do is give you guys access to the SNR controls!
Message 22 of 24
(446 Views)
07-02-2008 9:21 AM
Which realistically is never going to happen!
Message 23 of 24
(446 Views)
07-02-2008 9:25 AM
Grim... Self service is whats its all about today! Anyway, cheers for getting it sorted.
Message 24 of 24
(446 Views)
- « Previous
- 1
- 2
- Next »
