Major Disconecctions
- Re: Major Disconecctions
16-01-2010 12:08 AM
It Is not my router that is the problem.
I've purchased another one, and both do not work.
It all happened a week ago after I downloaded 30Gigs worth in a matter of 5 days.
Sicne then browsing is becomming impossible.... ive been a loyal member since around 2002 and dont want to have to switch ISPs
any help would be appreciated
16-01-2010 1:15 AM
16-01-2010 9:44 AM
16-01-2010 1:52 PM
we are on Plus Net 'Pro' using 20gig
Could that be the problem?
Adie:quote
16-01-2010 1:54 PM
16-01-2010 5:40 PM
i seriously think were being restricted
16-01-2010 5:53 PM
16-01-2010 9:30 PM
17-01-2010 2:42 PM
Oopsies
18-01-2010 9:33 AM
Quote Start End Duration
18/01/2010 07:20 N/A 2:11:31 (on going)
17/01/2010 20:05 18/01/2010 00:16 4:10:12
17/01/2010 18:26 17/01/2010 19:57 1:31:24
17/01/2010 18:15 17/01/2010 18:17 0:1:22
17/01/2010 17:14 17/01/2010 18:14 1:0:3
17/01/2010 15:41 17/01/2010 17:00 1:19:22
17/01/2010 14:33 17/01/2010 15:40 1:7:14
17/01/2010 13:47 17/01/2010 14:30 0:42:56
17/01/2010 10:10 17/01/2010 12:52 2:42:8
17/01/2010 02:13 17/01/2010 09:30 7:16:48
16/01/2010 21:40 17/01/2010 02:13 4:32:31
16/01/2010 20:46 16/01/2010 21:36 0:50:30
16/01/2010 17:34 16/01/2010 20:32 2:57:18
16/01/2010 13:30 16/01/2010 17:21 3:50:6
16/01/2010 09:27 16/01/2010 12:47 3:20:28
16/01/2010 00:54 16/01/2010 01:36 0:42:2
15/01/2010 23:54 16/01/2010 00:54 1:0:3
15/01/2010 22:04 15/01/2010 23:54 1:49:30
15/01/2010 20:13 15/01/2010 22:04 1:50:37
15/01/2010 19:16 15/01/2010 20:06 0:50:34
15/01/2010 16:45 15/01/2010 17:55 1:10:9
15/01/2010 09:00 15/01/2010 15:51 6:51:30
14/01/2010 21:04 15/01/2010 00:19 3:15:13
14/01/2010 18:17 14/01/2010 19:58 1:41:0
14/01/2010 15:39 14/01/2010 16:09 0:30:31
14/01/2010 10:10 14/01/2010 10:31 0:21:8
14/01/2010 09:11 14/01/2010 10:02 0:50:34
14/01/2010 07:56 14/01/2010 09:11 1:14:54
14/01/2010 06:52 14/01/2010 07:43 0:51:41
13/01/2010 22:40 14/01/2010 00:28 1:48:5
13/01/2010 21:06 13/01/2010 22:21 1:15:9
13/01/2010 20:46 13/01/2010 21:06 0:19:24
13/01/2010 18:01 13/01/2010 19:41 1:40:17
13/01/2010 16:33 13/01/2010 17:29 0:55:32
13/01/2010 15:43 13/01/2010 16:25 0:42:39
13/01/2010 09:16 13/01/2010 15:29 6:12:52
13/01/2010 09:12 13/01/2010 09:16 0:4:2
12/01/2010 22:49 13/01/2010 00:13 1:24:4
Are you connected to the master socket? Do you have any extension leads in use? Is every phone socket filtered?
19-02-2010 9:19 PM
20-02-2010 1:45 PM
21-02-2010 12:19 PM
Quote from: Chris Even if you have reached your usage allowance, that isn't going to cause the connection to actually drop. Looking at the recent connection logs on your line, something is definitely not right:
Yeah it's connected to the master socket
No we do not have any extension leads currently in use
And yes every phone socket is filtered.
But the problem persists and we keep getting disconnected, any other ideas of what the problem could be? (ADSL light on modem stays solid green at all times so it's quite confusing)
