Low SNR
- Low SNR
- « Previous
- Next »
Re: Low SNR
09-12-2014 2:44 PM
Message 46 of 48
(257 Views)
Re: Low SNR
09-12-2014 2:49 PM
Matthew,
You worded it just fine. It is more a matter that many people get the idea that FIXED means it can never vary EVER. As with most technology there is a certain context applicable to terms; here means the TARGET used at synch-up time is FIXED. ...there after it WILL vary.
I know that you know this, but I would guess that the OP does not.
Kevin
Kevin
Message 47 of 48
(257 Views)
Re: Low SNR
09-12-2014 4:31 PM
At least it'll be a 6 upon syncing, I'm happy - and I do understand even a 6 wouldn't necessarily 'fix' it, but it all helps..
I haven't forgotten about my other socket, its just getting someone to help move furniture etc
Message 48 of 48
(257 Views)
- « Previous
- Next »
