unable to access hotukdeals
rondelliott
New to PlusNet as of yesterday - can access all our usual websites except for hotukdeals.com (using Opera - could not locate remote server). Is this just us or is it a general problem - this is a vital site for my wife!
16 REPLIES 16
ossettbob
Re: unable to access hotukdeals
Just tried it. Straight in.
Fixes: 1,482
working fine here too, used often in our house and I'd get it in the neck too if it wasn't working Wink
Oldjim
Resting Legend
Fixes: 63
are you using a Plusnet router or your old one
Having said that I can't connect to them either using Plusnet DNS
Using tracert it is a DNS lookup problem
Changed to Google DNS and problem solved
Strat
Fixes: 565
A bit slow but I got there.
skybondy
Same problem here, not been able to access it for 2 days now.
Oldjim
Resting Legend
Fixes: 63
As a quick get around I suggest changing the DNS servers on your computer to use Google as the first one
MatthewWheeler
Fixes: 480
Hi guys.
We're aware customers are having issues with accessing hotukdeals
At the moment we're investigating further to find out what's the issue but as soon as we know more we'll update this thread.
Apologies for any inconvenience caused.
 Matthew Wheeler
bobpullen
Fixes: 315
Quote from: Oldjim
Does seem to be DNS related:
~$ dig hotukdeals.com @8.8.8.8
; <<>> DiG 9.3.4-P1.2 <<>> hotukdeals.com @8.8.8.8
; (1 server found)
;; global options:  printcmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 60866
;; flags: qr rd ra; QUERY: 1, ANSWER: 5, AUTHORITY: 0, ADDITIONAL: 0
;; QUESTION SECTION:
;hotukdeals.com.                        IN      A
;; ANSWER SECTION:
hotukdeals.com.        299    IN      A      104.20.14.114
hotukdeals.com.        299    IN      A      104.20.16.114
hotukdeals.com.        299    IN      A      104.20.12.114
hotukdeals.com.        299    IN      A      104.20.13.114
hotukdeals.com.        299    IN      A      104.20.15.114
~$ dig hotukdeals.com @212.159.6.10
; <<>> DiG 9.3.4-P1.2 <<>> hotukdeals.com @212.159.6.10
; (1 server found)
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: SERVFAIL, id: 29025
;; flags: qr rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 0, ADDITIONAL: 0
MatthewWheeler
Fixes: 480
Hi guys.
This should be fixed now. Is anybody still having issues?
 Matthew Wheeler
Strat
Fixes: 565
Loads much quicker now for me.
SpecialSystems
It's working here on our end now. Thanks for fixing this!
rondelliott
Many thanks to everyone for such prompt and helpful responses.
This is the first time I have ever tried posting and assumed there had been no response, not realising that I had been logged out after 60 minutes! Apologies to all concerned for apparent rudeness.
I was just looking up how to change my DNS server, as recommended, when my wife told me that hotukdeals was back on - all is well again!
Very impressed. Smiley
grumbler
Quote from: Matthew
Hi guys.
I am still "having issues" (fiber).
Oldjim
Resting Legend
Fixes: 63
You are not posting from a Plusnet connection but from your university - is this where you are having the problem
