Low Broadband speeds
Sarah8987
I am still experiencing low speeds and the replacement router has made little difference.
 Downstream sync is 34Mbps, well below normal.
I am thinking an engineer visit is needed.
Thank you
17 REPLIES 17
Fixes: 357
Re: Low Broadband speeds
@Sarah8987
It sounds very much like you have a problem - most likely not in your home/office environment, but more likely in the BT/OR network.
If the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
Sarah8987
Hi John.
Quiet Line Test clear.
I'm hoping one of the amazing Help Team can progress the fault.
Last time I had this problem it was a bad joint in an underground junction box.
Fixes: 357
OK Sarah - the best thing to do is report a fault via the 'broadband' link I provided - response times from staff on here are 3-5 days, on average.
Sarah8987
Thanks John.
Sarah8987
I did 'Report a problem' which, true to its name reported a problem but Plusnet were unable to request an engineer due to Openreach system issues.
Hopefully those issues are resolved.
Downstream sync is down to under 1Mbps on a 70Mbps line.
Fixes: 357
Thanks for the update , Sarah. Plusnet SHOULD follow this up tomorrow, but if you don't hear anything by lunchtime, post back and I'll see if I can prod anyone.
Note that you may not get an immediate response from me - I'm out from mid-morning until probably mid-afternoon.
Sarah8987
My TBB graph for today. Not very pretty.
Fixes: 357
That is HORRIBLE, @Sarah8987 !! What did the response to your fault report say?
Sarah8987
That an engineer visit was needed but they were unable book a date because of Openreach problems.
Fixes: 357
I would suggest you re-run the broadband bot again - hopefully now it is the working week, the 'problem' has disappeared. Note response times for Opennreach engineers may be a little protracted, due to the current dispute.
Sarah8987
Openreach hope to have the detected fault fixed within 3 working days....fingers crossed.
Sarah8987
Update:
Engineer came this morning and found a fault with the wall socket.
He converted it to single socket and dangly filter.
We will see how it goes when the kids come home.
Fixes: 357
That sounds a bit strange, Sarah. So far as I am aware, BT/OR retired the single socket quite some time back, and don't carry those any more. Was it one already in your home?
Sarah8987
No, he had one in the van and went to get it saying the double socket ones cause trouble.
