Loss of wifi at the same time every day
- Re: Loss of wifi at the same time every day
24-02-2011 11:25 AM
For the past few days, somewhere between 5:00 and 6:00 my wifi signal drops. I have to switch the router off and on, and everything connects again fine (except internet which takes a few minutes) I'm pretty sure it's not the broadband signal, because I'm on FTTC and don't turn off the modem, just the router to reset. I'm assuming that it coincides with a neighbour coming home from work and turning something on, but how can I prevent it?
24-02-2011 12:15 PM
Do you know if the wireless drops on the laptop (or PC) or the router ?
Just out of interest, do you have wireless controls (and stat) for your central heating ?
24-02-2011 12:51 PM
24-02-2011 4:38 PM
24-02-2011 5:01 PM
If it happens again this afternoon, I'll check back to see if any other networks have joined.
24-02-2011 6:01 PM
Obviously, if there are more networks on in the evening you may have to rethink.
24-02-2011 6:33 PM
24-02-2011 8:17 PM
Quote from: Jaggies As they are all on channel 1, try setting your own wireless channel to 11 - there won't be any overlap there.
BT Home Hubs generally use Channel 1,6,11 - If you change to something that isn't one of these. It'll probably be a lot better.
But then of course, It might not even be the BT hub that is causing the problem.
01-03-2011 7:09 PM
02-03-2011 11:00 AM
If you could maybe ask your neighbour what it is they switch on when they come in?
Jojo
18-03-2011 1:53 PM
We're on the end of 3 terraced houses, so only one neighbour actually next door, and they are generally short term (immigrants or students), so maybe it will cure itself. Turning the router (but not the modem) off and on sorts it every time. Very strange
18-03-2011 7:38 PM
just a thought, and maybe nothing but I had a router dropping problem ( which coincided with a line problem) and it was caused by a digital cordless phone. I did some research on it and found that it caused connection problems for wi-fi. The phone was an i-dect cordless phone. maybe, if your neighbours have family abroad, they wait until that time of night to 'phone home'.
Maybe have a look at their phone?
18-03-2011 11:05 PM
