I made a boo boo :(
- I made a boo boo :(
I made a boo boo :(
18-03-2011 2:11 AM
First of all, my ps3 is stuck on nat type 3 so i played around with a few settings and it worked for a while . I then decided to reset the router and since then nowt will connect not even my phone. I even tried a friends laptop that has never been on the network before to no avail. All the devices can see the network but thats about it. I have checked all of my cabling, reset the router, reboot the pc and ps3 all to no avail. I cant even connect to the thompson gate way. I dont get the option to put in the admin and password details etc. Only thing i can think of is the reset my line as maybe i have blocked the acces can somebody please try that pppwweeaassee.
I appologise for the spelling and grammar but typing this on a little phone screen is like splitting atoms.
Thanking you in advance.
beerman684
Re: I made a boo boo :(
18-03-2011 6:42 AM
Hope that will help
18-03-2011 8:58 AM
18-03-2011 9:55 AM
Is your laptop configured to obtain it's IP automatically?
18-03-2011 12:54 PM
18-03-2011 1:35 PM
However in Windows 7 if you click the Start button and type network connections into the search box.
Click on 'View Network Connections.
Right Click the network connection and select Properties.
Double click Internet Protocol Version 4 and you should see the set-up screen with a dot in the radio button alongside 'Obtain an IP address automatically.
18-03-2011 1:52 PM
18-03-2011 2:33 PM
18-03-2011 2:52 PM
18-03-2011 11:25 PM
19-03-2011 12:10 AM
regards beerman684
