Line reset please
- Re: Line reset please
Line reset please
14-08-2015 12:29 PM
I've just noticed I had a re-sync event yesterday, probably due to all the thunderstorms around, and it seems my default Noise Margin has gone up from 6dB to 9dB which gives me a much slower sync speed. The Line has been completely stable for some months prior to this, so is it possible to reset it back please? It has been stable in the past at 3dB, but that might be a step too far. It seems the DLM will only increase the Noise Margin, never reduce it, so no point in waiting for DLM to reduce it automatically? Thanks in anticipation.
Message 1 of 4
(675 Views)
3 REPLIES 3
15-08-2015 3:41 PM
Message 2 of 4
(380 Views)
17-08-2015 9:48 AM
Hi Adam, many thanks for your assistance. I'be just checked the Router log and I now sync at 9300 instead of 8300 as previously reported. It should make a nice improvement in downloading, too, especially as Apple have just released several system updates. "Done proud" would be appropriate, I think!
Message 3 of 4
(380 Views)
18-08-2015 1:49 PM
Message 4 of 4
(380 Views)
