Problem with Gateway 195.166.130.141
kjpetrie
A few minutes ago I was re-rerouted through gateway 195.166.130.141 and lost all forward connectivity from there:
xxxx@master ~]$ ping -c2 195.166.130.141
PING 195.166.130.141 (195.166.130.141) 56(84) bytes of data.
64 bytes from 195.166.130.141: icmp_req=1 ttl=63 time=26.3 ms
--- 195.166.130.141 ping statistics ---
2 packets transmitted, 1 received, 50% packet loss, time 1001ms
rtt min/avg/max/mdev = 26.303/26.303/26.303/0.000 ms
[xxxx@master ~]$ ping -c2 8.8.8.8
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
--- 8.8.8.8 ping statistics ---
2 packets transmitted, 0 received, 100% packet loss, time 999ms
[xxxx@master ~]$ ping -c2 212.159.6.9
PING 212.159.6.9 (212.159.6.9) 56(84) bytes of data.
--- 212.159.6.9 ping statistics ---
I disconnected and reconnected manually and am now routed through 195.166.130.139 which is working, as you see!
Just thought I'd let you know there appears to be a fault beyond 195.166.130.141.
1 REPLY
Fixes: 20
Re: Problem with Gateway 195.166.130.141
This was the last time something similar happened to me. It just seems to be something that happens occasionally but very infrequently.
