Line drops
Re: Line drops
@PabloBruno
Your connection didn't look very stable over Sunday evening with a few drops, the period early Monday morning could be a fault on the network somewhere, suggested by the multiple drops over the time period 00:30 (ish) to 02:45 (ish) this is the time period Openreach and BT perform network maintenance work.
In some circumstances the front plate of the MK4 Openreach Master Socket can become poorly seated as it's only held in position with clips rather than screws, the could cause intermittent noise on the line, which would be noticeable on a landline phone as crackling.
I would keep an eye on things for now to see if anything further happens.
Have you noticed a drop of speed since the weekend?
HTH
NB; it is recommended the Hub is kept switched on at all times to prevent the headend system thinking there is a fault when the Hub is powered off.
PabloBruno
Re: Line drops
I have now noticed another drop, so would really appreciate some more action here please.
I will be around tomorrow (Sat) and free to take a call now this busy work week is over.
Any advice and/or help would be much appreciated.
Many thanks
adamwalker
Fixes: 223
Re: Line drops
Hi @PabloBruno Sorry about the connection dropouts you've been experiencing. Line tests aren't revealing any obvious causes for that. Mind sending over photos of the socket where the router plugs into the wall and also the back of the router just so we can check your setup? Feel free to send those over on a PM to me if you'd prefer.
 Adam Walker
PabloBruno
Re: Line drops
MatthewWheeler
Fixes: 503
Re: Line drops
Hi @PabloBruno
Things look to be more stable now.
How has the connection been on your end the past few days?
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
PabloBruno
Re: Line drops
Slightly more stable but the average speed test has gone down from 56Mbps to 48Mbps.
I would still appreciate someone looking into what the problem was and if it is likely to resurface.
PabloBruno
Re: Line drops
Can someone get back to me please?
adamwalker
Fixes: 223
Re: Line drops
Hi, we'd not be able to identify the exact cause of a past issue as we can only investigate current problems or recurring ones. I hope things remain stable with your connection but do shout up if there's any more issues and we'll get back on the case for you.
 Adam Walker
PabloBruno
Re: Line drops
I just had another drop, so please will you finally look into this.
In the past I have had a few drops that then led to very lengthy outages. I would like to nip this in the bud.
I first reported this two weeks ago and had no meaningful responses. Please advise.
Re: Line drops
A drop at 1am will most likely be DLM optimising your sync speed based on the errors detected in the previous 24 hours
PabloBruno
Re: Line drops
As a non-BT technician, I don't know what that means. All I do know is that the service I am paying for, that has had a troubled past, is patchy. I would like it to stop please.
Re: Line drops
