Line Reset
- Re: Line Training or Reset
Line Reset
Tuesday
Advise would be appreciated.
Regards Jono.
Tuesday
Hello , About 9 days ago my internet kept dropping out and all so had a lot of errors upstream and down, Ive since found the problem and fixed it, could someone advise Will my line gradually settle and go back to normal or do I have to ask for a reset of line, I have no errors and line is stable.Stats are now
| SNR Margin (dB) | 7 | 6.4 |
| Line Attenuation (dB) | 10.8 | 6.7 |
| Errors (pkts) | 0 | 0 |
Any help would be appreciated
Re: Line Reset
Tuesday
@jono What was the cause of your disconnections/drop-offs? How close to 'normal' is your present connection?
So long as the underlying are actually resolved, the DLM (dynamic line management) should bring you to back to best achievable speeds over a couple of weeks or so.
Re: Line Reset
Tuesday
Regards
Jono
Re: Line Reset
Tuesday
It should recover automatically, but if it hasn't after a couple of weeks, call Support and ask them to to do a reset.
yesterday
Margins look reasonable, but are a tad meaningless without the sync speeds.
yesterday
- last edited
11 hours ago
by
Hello, Sorry about that, don't know why the stats disappeared, I got a bit confused and lost the original topic but it's obviously reappeared hence your reply but thanks for replying. I have been told line should retrain over time.
Regards
jono
Threads merged
yesterday
They could if the line is not chronically banded.
