Legacy PAYG Pro - Drop in speed?
- Re: Legacy PAYG Pro - Drop in speed?
20-06-2011 1:35 PM
I've spoken to 'The Boss', and she can manage without the internet for a day or so this week so please can you action the move to another VP when you have a mo'
-Mat
20-06-2011 5:31 PM
I've replied to that email so I'll let you know when I hear back.
Jojo
21-06-2011 10:52 AM
22-06-2011 3:29 PM
I've received an email telling me that they've placed to order to move you to a different VP and they'll let me know when it's complete.
Jojo
22-06-2011 3:35 PM
I'll wait for your email then and I won't panic if the internet disappears for a couple of hours
-Mat
23-06-2011 4:50 PM
[quote=BT email]I can confirm that the order to move your customer on to a different VP has now completed.
I've also emailed you confirmation of this.
Jojo
23-06-2011 6:22 PM
excellent news indeed. I've just run a speedtest and get much better results. Almost 7M/s. Only strange thing is running the BT Speedtester gives tells me I've entered an invalid phone number:
Authorisation failed Incorrect Telephone Number - Please try again
I guess that is because of the lift and shift and will sort itself out over time.
Thanks for a speedy response and excellent service
-Mat
24-06-2011 12:00 PM
Quote from: mlavende Only strange thing is running the BT Speedtester gives tells me I've entered an invalid phone number:
It should do, The circuit ID has changed but the number is still the same.
Jojo
24-06-2011 1:22 PM
Have fun
-Mat
24-06-2011 3:15 PM
08-07-2011 9:57 PM
my speeds seem to have dropped down again. The latest speedtest shows less than 5mb/s with all things as before. One thing I have noticed on my router is the Noise Margin and Attenuation. The figures are:
Up Down
Noise Margin 24 15
Attenuation 10 13
Shouldn't they be lower considering the attached speedtest results. Can you do anything to lower the noise margin or is something wrong at my end please?
-Mat
09-07-2011 10:41 AM
The attenuation is dependant on how far you are from the exchange and sometimes by line quality. 13db says you are less than 1km from the exchange.
When the router and exchange negotiate the sync speed they go as high as they can without the noise margin dropping below the target. As you sync faster the noise margin drops. In your case you have reached the limit of 8128 possible using ADSL1 and so you have some spare noise margin left over. This tells us two things: your line has such a healthy noise margin it will be very resistant to interference and when you move to ADSL2+ it will sync a lot, lot faster.
I'd say your drop in speed still looks like exchange contention.
09-07-2011 10:48 AM
Thanks for that. I've been taking some bt speed tests at regular intervals and the results are pretty much what they were earlier in in this thread. Generally around half what they should be and certainly not what I was getting a few months ago. I'll take a few more throughout the weekend and post them. Maybe someone can suggest a course of action then.
-Mat
09-07-2011 2:24 PM
11-07-2011 8:53 AM
Bit busy this weekend but I'll try and run some tests for various times over the next few days.
Strangely enough, last night my speeds seem to have returned to normal since I downloaded over 20GB between midnight and 8am this morning. Not sure if anything has been sorted but I'm not complaining 🙂
I'll keep monitoring
cheers
-Mat
