Lease time (F.A.O. Chris Pettitt)
cbcadmin
What is the lease time on Plusnet please?
Keef- Sheerness Kent UK - Vodafone FTTP via THG3000 & Three via ZTE MF286D
Previously - NowTV, John Lewis, Shell Energy, Plusnet, Sky, EE, New Call Telecom/Fuelbroadband, Virgin/NTL/Bell Cable, Crosswinds, IC24, FreeOnlineNet, X-Stream, Totalise, Freeserve, Force9, TescoNet, AOL, Freenetname, Pipex, E7
66 REPLIES 66
Pettitto
Fixes: 5
Re: Lease time (F.A.O. Chris)
Can you explain a little more what you mean by the 'lease time'?
It might just be me being  Crazy
Fixes: 1,484
As in IP address lease?
cbcadmin
Quote from: dvorak
IP address
Yep, thanks dvorak
Pettitto
Fixes: 5
Re: Lease time (F.A.O. Chris Pettitt)
Let me find out for you Smiley
cbcadmin
Quote from: Chris
Let me
Thanks and ..................... good luck! Cheesy
Pettitto
Fixes: 5
As far as I am aware the lease time is 24 hours for a Dynamic IP Address.
If you'd like, I can flag this question to get further clarification, but we'll be unlikely to get an answer until Monday.
cbcadmin
Quote from: Chris
If you'd like
Yes please.
Been waiting for several months for an answer a few more days won't matter. Wink
Pettitto
Fixes: 5
Well your IP will always remain the same unless your connection drops. Is there a specific reason you're wanting to know what the lease time is?
Anotherone
Champion
Fixes: 21
Keeef, are you effectively asking how long after you stop using a particular IP address it might get re-allocated to another user?
ReedRichards
Seasoned Pro
Fixes: 25
I was recently approaching 900 hours of continuous up time; then there was a power cut.  So I would have held the same IP address for all that time.
Pettitto
Fixes: 5
Is that 900 hours without a single PPP session drop?
Chris
Legend
Fixes: 169
The lease time isn't actually that long as on each PPP disconnection you'll be assigned a new IP address even if the previous connection only lasted a few seconds.
If you need a static IP (and aren't on Value) you can add one via the add-ons section of the website.
ReedRichards
Seasoned Pro
Fixes: 25
Quote from: Chris
As far as I know, yes; that was the WAN up time reported by my Netgear router.  I cannot be certain as the router event log was lost when the power failed.  But at present it tells me the most recent WAN session has lasted 40 hour whereas the router uptime is around 400 hours (since the day after that power failure, I think).
Pettitto
Fixes: 5
That's pretty impressive!
Personally I have a Static IP as I occasionally host games and do other bits and bobs.
